discount tyres dan Posted November 8, 2006 Report Share Posted November 8, 2006 today i checked the geom a honda jazz, this is the second one i have doe recently and both have had a problem with the o/s/r toe. both cars this was reading +3.0mm, the first one was for a local body shop, the car then had a new rear axle and was re-tested giving the same result, i was wondering if this is just co-incidence or if there is a problem with the jazz. anyone else able to get hold of a printout for a jazz? Quote Link to comment Share on other sites More sharing options...
melin Posted November 8, 2006 Report Share Posted November 8, 2006 hi dan on the same note i checked a brand new astra h today with 19 miles on the clock only front toe adjustable n/s/r -1.5 reading should be plus .5 o/s/r all good how did that happen ( built by robots geo not checked before delivery ) Quote Link to comment Share on other sites More sharing options...
Tony Posted November 8, 2006 Report Share Posted November 8, 2006 No known problem to wim... It is just possible the D-cam factory default position is +3mm and the body shop set the adjuster at the default... If i were working blind i would! Quote Link to comment Share on other sites More sharing options...
discount tyres dan Posted November 8, 2006 Author Report Share Posted November 8, 2006 the honda jazz doesnt have adjustable rear toe, just seems a bit odd that 3 axles should come up with the same reading. Quote Link to comment Share on other sites More sharing options...
Tony Posted November 8, 2006 Report Share Posted November 8, 2006 the honda jazz doesnt have adjustable rear toe, just seems a bit odd that 3 axles should come up with the same reading. What is the thrust position Dan? and are there complaints regarding the steering wheel angle? Quote Link to comment Share on other sites More sharing options...
discount tyres dan Posted November 8, 2006 Author Report Share Posted November 8, 2006 the thrust angle on the one today was 0"13' no complaints of the steering wheel being off line, front total toe was spot-on 0.00mm but one was +1.0mm and the other was -1.0mm, i didnt drive the car before but i did after and all seemes ok. Quote Link to comment Share on other sites More sharing options...
Tony Posted November 8, 2006 Report Share Posted November 8, 2006 the thrust angle on the one today was 0"13' no complaints of the steering wheel being off line, front total toe was spot-on 0.00mm but one was +1.0mm and the other was -1.0mm, i didnt drive the car before but i did after and all seemes ok. Then it's wise to conclude that although the positions are unusual the damage is either undetectable or irrelevant... Both conclusions benefit the customer, although the reasons for the positions remain suspicious to us in the know Quote Link to comment Share on other sites More sharing options...
