Nissan 350Z
Tony
wow! was it a case of excessive tyre wear or something deeper?
Deeper... The 350 has had an ongoing issue regarding inner front tyre wear and heel/toe wear.. wim dealt with the heel pattern of wear in 05 over the pond, and although the results were not released the heel problem seemingly has been sorted.... But the inner wear remains hence this desperate move on the toe settings... Secretly i feel this story has another chapter to go yet <_<
do you know anyone that has driven a 350z with the old settings and then the new settings? if you do what difference (if any) did they say they felt in the way the car drives..
does that make sence?
My domestic contact with 350z owners is relatively small... Most times my contact is only with the main dealer...
  • 6 months later...
Update
Nissan have revised the position again.. Total front toe +2mm (1mm partial)
This example had 12k on the clock needed four tyres and had front toe positions of
nsf: -.3mm
osf: +.6mm
Total: +.3mm
Resulting in this....
So for now +2mm is the guideline :thumbsup_anim:
