Tony Posted August 26, 2010 Report Share Posted August 26, 2010 Those with a weak heart look away.. The quality referred to as "ride comfort" is affected by a variety of factors, including high frequency vibrations, body booming, body roll and pitch, as well as the vertical spring action normally associated with a smooth ride. If the vehicle is noisy, if it rolls excessively in turns, or lurches and pitches during acceleration and braking, or if the body produces a booming resonance, occupants will experience an "uncomfortable ride." The ride quality normally associated with the vehicle's response to bumps is a factor of the relatively low frequency bounce and rebound movements of the suspension system. Following a bump, the undamped suspension (without shocks) of a vehicle will experience a series of oscillations that will cycle according to the natural frequency of the system. Ride is perceived as most comfortable when the natural frequency is in the range of 60 to 90 cycles per minute (CPM), or about 1 Hz to 1.5 Hz. When the frequency approaches 120 CPM (2 Hz), occupants perceive the ride as harsh. Consequently, the suspension of the average family sedan will have a natural frequency of about 60 to 90 CPM. A high-performance sports car will have a stiffer suspension with a natural frequency of about 120 to 150 CPM (2 to 2.5 Hz). Originally, human sensitivity to ride frequency was believed to be associated with the natural oscillations of an adult human body during a walking gait. An adult walks at the rate of about 70 to 90 steps per minute (frequency), and the torso moves up and down about 2 inches (amplitude) with each step. Early designers therefore attempted to constrain vehicle oscillations to those limits, the ride was indeed comfortable, and the theory was therefore believed to be correct. Today, our information about human sensitivity to vibrations is more sophisticated. We know that amplitude affects human sensitivity to frequency, and that there are some frequencies that are especially uncomfortable. For example, a frequency in the range of 30 to 50 CPM will produce motion sickness. The visceral region of the body objects to frequencies between 300 and 400 CPM. The head and neck regions are especially sensitive to vibrations of 1,000 to 1,200 CPM (18 to 20 Hz). These are the types of vibrations that are likely to emanate from the tires or from axle hop. Longitudinal oscillations are sensed primarily in the torso. Surprisingly, humans are most uncomfortable with longitudinal vibrations in the 60 to 120 CPM range (the region of greatest comfort for vertical vibrations). Discomfort from longitudinal disturbances occur when the vehicle pitches or when the seats lean rearward at a higher-than-normal angle. The perception of ride quality is degraded by virtually any disturbance experienced by the occupant. Human sensitivity varies according to the nature of the disturbance. Consequently, a "good ride" depends on the overall design of the vehicle, rather than just the design of the suspension system. To produce a comfortable ride, the high-frequency vibrations of wind and drive-train noise must be minimized and properly isolated, and the suspension must be set in appropriate rubber mountings to isolate high-frequency roadway-induced vibrations. However, the natural frequency of the suspension system is still considered the cornerstone of a comfortable ride. The static deflection rate of the suspension determines its natural frequency. Static deflection is the rate at which the suspension compresses in response to weight. Other factors, such as the effects of damping (shocks) and system friction, alter the natural frequency of the suspension system. However, the primary determinate is the undamped static deflection rate. If this rate is used in calculations, results will likely be very close to the actual value needed for a smooth ride. The static deflection rate of the suspension is not the same as the spring rate. Springs are located inboard of the wheels where they are normally subjected to the mechanical advantage of the suspension linkages. Static deflection is related to the distance the sprung mass (essentially the body) moves downward in response to weight. A static deflection of 10 inches in response to a weight equal to that of the sprung mass will produce a natural frequency of 1 Hz. A 5 inch deflection produces a 1.4 Hz frequency, and a 1 inch deflection results in a 3.13 Hz frequency. This excludes the recognized "normal or steady state" human frequency or any pneumatic coefficient laws acting within this melting pot. Quote Link to comment Share on other sites More sharing options...
