Bazza Posted February 18, 2010 Report Share Posted February 18, 2010 in an effort to reduce understeer on the starlet i was advised to fit a rear ARB many reports state that its one of the best handling mods to carry out so duly ordered and fitted a rear ARB, not one to do things by half i also ordered an uprated front ARB, until then it was running a not so uprated front ARB the difference was....no difference to be honest and still suffering from understeer this is contrary from many good reports on how much better it should have been so my thoughts are maybe that by uprating the front ARB it counteracted uprating the rear next thoughts were by fitting the not so uprated front ARB back to see what differences it might make question time: Is there a relationship between front and rear ARB's and understeer/oversteer ? Is it feasible that one counteracted the other ? Quote Link to comment Share on other sites More sharing options...
hms Posted February 18, 2010 Report Share Posted February 18, 2010 I'm probably totally wrong on this as my memory... now what were we talking about! It's down to the relationship of front/rear ARB ratios. A lighter ARB at the rear than the front would provoke oversteer. (If provoke is not too strong a work) So if you uprated the rear and the front, the front/rear rations may have stayed the same/similar, and hetherefore no change on under/oversteer. You may have notices something tho' on body roll. Anyone feel free to correct me! h Quote Link to comment Share on other sites More sharing options...
Tony Posted February 18, 2010 Report Share Posted February 18, 2010 Where is the understeer 1: Steady state 2: Corner entry 3: Corner exit Quote Link to comment Share on other sites More sharing options...
Bazza Posted February 18, 2010 Author Report Share Posted February 18, 2010 Where is the understeer1: Steady state 2: Corner entry 3: Corner exit entry / exit any large sweeps and understeer creeps in, lifting off to correct but thats loosing time ! Quote Link to comment Share on other sites More sharing options...
Tony Posted February 18, 2010 Report Share Posted February 18, 2010 Entry I would reduce the front coils preload and remove the toe-out, exit increase preload in the rear shocks... If the problem is "steady state" then that's another completely different issue. Quote Link to comment Share on other sites More sharing options...
Bazza Posted February 18, 2010 Author Report Share Posted February 18, 2010 EntryI would reduce the front coils preload and remove the toe-out, exit increase preload in the rear shocks... If the problem is "steady state" then that's another completely different issue. numpty question : whats "steady state" Quote Link to comment Share on other sites More sharing options...
Mat Posted February 18, 2010 Report Share Posted February 18, 2010 try a run with the front bar disconnected..... Quote Link to comment Share on other sites More sharing options...
Bazza Posted February 18, 2010 Author Report Share Posted February 18, 2010 try a run with the front bar disconnected..... that would be easy enough to try Quote Link to comment Share on other sites More sharing options...
CIH Posted February 19, 2010 Report Share Posted February 19, 2010 EntryI would reduce the front coils preload and remove the toe-out, exit increase preload in the rear shocks... If the problem is "steady state" then that's another completely different issue. numpty question : whats "steady state" Think of longer, sweeping bends with fairly constant steeering input. Probably at higher speeds. Atleast, that's what I always understood it to mean.. Quote Link to comment Share on other sites More sharing options...
Tony Posted February 19, 2010 Report Share Posted February 19, 2010 EntryI would reduce the front coils preload and remove the toe-out, exit increase preload in the rear shocks... If the problem is "steady state" then that's another completely different issue. numpty question : whats "steady state" Think of longer, sweeping bends with fairly constant steeering input. Probably at higher speeds. Atleast, that's what I always understood it to mean.. Spot on..... Quote Link to comment Share on other sites More sharing options...
Tony Posted February 19, 2010 Report Share Posted February 19, 2010 Where is the understeer1: Steady state 2: Corner entry 3: Corner exit entry / exit any large sweeps and understeer creeps in, lifting off to correct but thats loosing time ! Blimey that's a bit of everything..... Entry needs the bump turned down and as said the neg toe removed then possibily the rear rebound increased. Quote Link to comment Share on other sites More sharing options...
