Tony Posted October 11, 2009 Report Share Posted October 11, 2009 This extends the ball-joint in the hope the wishbone stays horizontal after lowering the chassis..... I'm not overly keen on them but they seem to work regardless. Quote Link to comment Share on other sites More sharing options...
Rich Posted October 11, 2009 Report Share Posted October 11, 2009 Would this help the bushes last longer then? Quote Link to comment Share on other sites More sharing options...
hms Posted October 11, 2009 Report Share Posted October 11, 2009 How does this work? If it only has male and female ends then doesn't the fitment allow for the ends to float whereas without it fitted there would be no movement? Sorry if that is not clear, but does the new bit allow the TRE and the hub to move independently of each other? h Quote Link to comment Share on other sites More sharing options...
CIH Posted October 12, 2009 Report Share Posted October 12, 2009 They were peeping about "roll centre" adjusters on the SXOC recently. These look like the same thing. Quote Link to comment Share on other sites More sharing options...
Tony Posted October 12, 2009 Author Report Share Posted October 12, 2009 How does this work?If it only has male and female ends then doesn't the fitment allow for the ends to float whereas without it fitted there would be no movement? Sorry if that is not clear, but does the new bit allow the TRE and the hub to move independently of each other? h The idea is to move the steering arm away from the wishbone so that they both have the same radii on compression. The ball joint still works the same it's just a case of keeping the components parallel with each other. Quote Link to comment Share on other sites More sharing options...
CIH Posted October 12, 2009 Report Share Posted October 12, 2009 ah, a cure for bumpsteer ? Quote Link to comment Share on other sites More sharing options...
Tony Posted October 12, 2009 Author Report Share Posted October 12, 2009 ah, a cure for bumpsteer ? Indeed young Luke. Quote Link to comment Share on other sites More sharing options...
CIH Posted October 12, 2009 Report Share Posted October 12, 2009 looks like it could add preload to the arb without adjustable drop-links ? Quote Link to comment Share on other sites More sharing options...
Tony Posted October 13, 2009 Author Report Share Posted October 13, 2009 looks like it could add preload to the arb without adjustable drop-links ? That would only change if the ARB anchor point was longer/ shorter (horizontal plane) in this case the actual height would not add/ subtract torsional load. Quote Link to comment Share on other sites More sharing options...
V0v4ik Posted November 30, 2009 Report Share Posted November 30, 2009 By a photo, it VW Jetta? I adjusting some such cars, but such design of tie rod did not see.I shall not understand as it is adjusted? Quote Link to comment Share on other sites More sharing options...
Tony Posted November 30, 2009 Author Report Share Posted November 30, 2009 What is that cars complaint? Is it bump steer or lazy steering responce? Quote Link to comment Share on other sites More sharing options...
V0v4ik Posted November 30, 2009 Report Share Posted November 30, 2009 I just asked how to do it. Quote Link to comment Share on other sites More sharing options...
jammy Posted November 30, 2009 Report Share Posted November 30, 2009 sweet could of done with them on the last astra after slammin her on the ground lol are thay easy fabricated do you think??? Quote Link to comment Share on other sites More sharing options...
V0v4ik Posted December 1, 2009 Report Share Posted December 1, 2009 Left steering arm installed at the factory, is not regulated. The controllable thrust is established during the replacement. That's all I wanted to hear. Quote Link to comment Share on other sites More sharing options...
Tony Posted December 1, 2009 Author Report Share Posted December 1, 2009 You need these Quote Link to comment Share on other sites More sharing options...
djwozza Posted December 1, 2009 Report Share Posted December 1, 2009 Hmmm, looks like I need a similar thing for mine, but in my case the top ball joint needs adjustment after lowering, to bring the camber back into range that will not cause premature tyre wear. I will start a seperate thread for this. Quote Link to comment Share on other sites More sharing options...
Tango Posted December 1, 2009 Report Share Posted December 1, 2009 Hmmm, looks like I need a similar thing for mine, but in my case the top ball joint needs adjustment after lowering,to bring the camber back into range that will not cause premature tyre wear. I will start a seperate thread for this. Tony/Wozza, I have found a site that appears to supply the camber adjusters I have on my Is250 and they're the same fit for the IS200/300. Any good? http://www.iapdirect.com/search.php?mode=search&page=1 Quote Link to comment Share on other sites More sharing options...
djwozza Posted December 2, 2009 Report Share Posted December 2, 2009 Great find Tango, I found something similar on E-bay motors (USA) TH Motorsports yesterday, (item number 370143306876) deffo looks like I will get from one of these two places, many many thanks mate !! P.S sorry for disturbing you while you are away Quote Link to comment Share on other sites More sharing options...
