Tony Posted June 11, 2008 Report Share Posted June 11, 2008 I thought all series had to have a cage.....I mean even Banger racing has to have one Quote Link to comment Share on other sites More sharing options...
Prolex-UK Posted June 11, 2008 Report Share Posted June 11, 2008 not this one..............or time attack club challenge Quote Link to comment Share on other sites More sharing options...
Tony Posted June 11, 2008 Author Report Share Posted June 11, 2008 I'm pleased for everyone since this keeps down costs but it does seem odd Quote Link to comment Share on other sites More sharing options...
Bazza Posted June 11, 2008 Report Share Posted June 11, 2008 banger racing tends to use an acro prop stuck behind the driver there is of course a big chance they will roll over there is no approval needed certain drifting championships also require roll cages and they need to be approved some MSA events will require an approved cage normally where the vehicles are mainly for road use they avoid the requirement for cages, because when a cage is fitted it is deemed unsafe not to be wearing a helmet, .........bit much running down to sainsburys with a helmet on ! Quote Link to comment Share on other sites More sharing options...
scorps Posted June 11, 2008 Report Share Posted June 11, 2008 bit much running down to sainsburys with a helmet on ! Why?..........i do it all the time Quote Link to comment Share on other sites More sharing options...
Bazza Posted June 11, 2008 Report Share Posted June 11, 2008 bit much running down to sainsburys with a helmet on ! Why?..........i do it all the time Quote Link to comment Share on other sites More sharing options...
Tony Posted June 11, 2008 Author Report Share Posted June 11, 2008 banger racing tends to use an acro prop stuck behind the driverthere is of course a big chance they will roll over there is no approval needed certain drifting championships also require roll cages and they need to be approved some MSA events will require an approved cage normally where the vehicles are mainly for road use they avoid the requirement for cages, because when a cage is fitted it is deemed unsafe not to be wearing a helmet, .........bit much running down to sainsburys with a helmet on ! I hear you and i'm not being argumentative but TA is not intended for the road and the cars pushed way beyond the normal level of driving Quote Link to comment Share on other sites More sharing options...
Bazza Posted June 11, 2008 Report Share Posted June 11, 2008 banger racing tends to use an acro prop stuck behind the driverthere is of course a big chance they will roll over there is no approval needed certain drifting championships also require roll cages and they need to be approved some MSA events will require an approved cage normally where the vehicles are mainly for road use they avoid the requirement for cages, because when a cage is fitted it is deemed unsafe not to be wearing a helmet, .........bit much running down to sainsburys with a helmet on ! I hear you and i'm not being argumentative but TA is not intended for the road and the cars pushed way beyond the normal level of driving time attack: pro drivers must have roll cages club drivers its only recommended Quote Link to comment Share on other sites More sharing options...
Tony Posted June 11, 2008 Author Report Share Posted June 11, 2008 banger racing tends to use an acro prop stuck behind the driverthere is of course a big chance they will roll over there is no approval needed certain drifting championships also require roll cages and they need to be approved some MSA events will require an approved cage normally where the vehicles are mainly for road use they avoid the requirement for cages, because when a cage is fitted it is deemed unsafe not to be wearing a helmet, .........bit much running down to sainsburys with a helmet on ! I hear you and i'm not being argumentative but TA is not intended for the road and the cars pushed way beyond the normal level of driving time attack: pro drivers must have roll cages club drivers its only recommended I see Quote Link to comment Share on other sites More sharing options...
