Taff7996 Posted June 5, 2021 Report Share Posted June 5, 2021 Hi My T6 California Ocean has excess wear on outside edge of R/N/S Van has VW 30mm lowering springs fitted, rear tyres are Continental 235/55/R17 103y and at 48psi factory fitted Last week had Hunter lazer alignment checked, no major issues found! No adjustments made Here is a link to the dealer service on Friday showing tyre wear https://video.citnow.com/vx2pwKs79Z_ Having new rear boots fitted on Monday any advise grateful received Quote Link to comment Share on other sites More sharing options...
Tony Posted June 7, 2021 Report Share Posted June 7, 2021 Hi They have measured the chassis and not taken the mod's into account, If the wear was confined to about 10% of the tyre then the issue is camber. If the wear and given the tyre a sharp leading edge then to criminal is toe. We correct many VW's and can fit adjuster bushings so we can deal with the problems. 1 Quote Link to comment Share on other sites More sharing options...
