Rich Posted January 21, 2020 Report Share Posted January 21, 2020 On the way to work this morning a 4x4 had broken down, the OSF wheel was right up inside the arch and that corner was practically on the road. It was still there when I came home so they obviously don't have breakdown cover! What can cause the suspension to just collapse like that, broken lower arm or ball joint? Scary to think that could've happened at speed! Quote Link to comment Share on other sites More sharing options...
Tony Posted January 21, 2020 Report Share Posted January 21, 2020 Broken coil or burst airbag..... On most cars the helix would drop 30mm. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 21, 2020 Author Report Share Posted January 21, 2020 I think this was more than a broken coil, it was almost touching the ground so had dropped more than 30mm. I'll have to see if the dashcam picked it up. Quote Link to comment Share on other sites More sharing options...
adam_r Posted January 21, 2020 Report Share Posted January 21, 2020 Maybe broken hub or snapped suspension arm? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 22, 2020 Report Share Posted January 22, 2020 If the arm was broken it would be undrivable,,,,, I think the coils are pig-tailed meaning the top/ bottom helix tend to snap which changes the trim height by 30mm for each helix. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 29, 2020 Author Report Share Posted January 29, 2020 It was undriveable, hence it had been left on the road all day. That's why I don't think it was a spring but an arm. I have been do busy this last week I've not had time to check my dashcam. I guess you wouldn't even get a warning if an arm broke, it would just go. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 30, 2020 Report Share Posted January 30, 2020 It's very rare the arm would brake.... if a knuckle broke then there would have been plenty of banging and clonking prior to the failure. Quote Link to comment Share on other sites More sharing options...
