Impossible adjustment request.....
This is a instruction from Lamborghini for adjusting the front toe angle. The front toe angle is a compliance angle, meaning if FWD ( pulling ) RWD ( pushing ) the desire is a dynamic zero. The variant between the cars setting is the bushing size/ compliance.
This instruction by Lamborghini isn't possible.....
Each wheels toe position, value, adjustment is compensation for a bend and bushing compliance. If the thread length is to read the same then no adjustment can be made??
In addition, the second paragraph totally belays the first instruction?........ I think it's worded incorrectly?
Instruction comes from Lamborghini. Hunter just adds the instructions within the system.
The command defies logic if it was acted as instructed since the toe angle is defined buy each wheels toe position and not the visible threads.
I think they mean... Measure the value and ensure its the same on both sides after adjustment. This would indicate that the chassis is true. If the value from left and right differ, then there may be a bend/ damage.
However in first principle, its not written correctly
