Tony Posted July 13, 2019 Report Share Posted July 13, 2019 HOTW for me....... A major design flaw. Here we have a rear after market camber adjuster with an inner and outer lock nut. How the hell do they think anyone is going to unlock/ lock the inner nut Outer Inner All they needed to do is make a longer inner rose joint..... Simple! Quote Link to comment Share on other sites More sharing options...
Rich Posted July 13, 2019 Report Share Posted July 13, 2019 Did you need to adjust it? Whoever designed it obviously hasn't adjusted them before! Quote Link to comment Share on other sites More sharing options...
Tony Posted July 14, 2019 Author Report Share Posted July 14, 2019 Yep.... Had to disconnect the outer. Crack the main bar away from the inner lock nut. Adjust the bar then run the inner lock down the thread, finalize the adjustment then lock both up. Quote Link to comment Share on other sites More sharing options...
jammy Posted November 23, 2019 Report Share Posted November 23, 2019 Couldn't of made it more awkward Quote Link to comment Share on other sites More sharing options...
