Rich Posted June 20, 2019 Report Share Posted June 20, 2019 The missus got home and said there is a terrible rattling noise from the rear of the Lexus. I knew immediately what it would be and sure enough the mount points have corroded on the shield. So can I use the car without, just how effective are they really? Any ideas on how I could repair it? The 2 holes I can use a washer but it's the ones on the edge I'm not sure about. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 20, 2019 Report Share Posted June 20, 2019 Is it the upper shield. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 20, 2019 Author Report Share Posted June 20, 2019 1 hour ago, Tony said: Is it the upper shield. Yes, goes over the backbox. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 21, 2019 Report Share Posted June 21, 2019 If it's just the back box i wouldn't worry about it because the box doesn't get very hot. If it were the cat then that's another story. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 22, 2019 Author Report Share Posted June 22, 2019 Yeah if it was the cat then I'd definitely get it sorted asap. I had half of it fall off the Accord and needed it strapped back on. I think the backbox shield is probably to reduced the heat for rear passengers. I'll try and fix it though. I'm thinking some strong foil trays folded to shape and riveted in place might work. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 22, 2019 Report Share Posted June 22, 2019 That'll work since it's not heavy. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 22, 2019 Author Report Share Posted June 22, 2019 I'll give it a go. Hopefully the bolts won't be too rusty to undo. Quote Link to comment Share on other sites More sharing options...
Steve-O Posted June 22, 2019 Report Share Posted June 22, 2019 How funny - the same shield on our CT200 became noisy so we took it in. They replaced it FOC under the extended warranty we had which was nice. The only thing i'd say is the batteries are in and around that area. Not sure how they will like any additional heat radiation... be careful!. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 23, 2019 Author Report Share Posted June 23, 2019 We don't have a warranty any more but it was only serviced and MOT'd 3 weeks a go, it must've been getting loose then. I thought the same with the battery but the backbox wasn't even hot when I looked under the car. I'll definitely try and put it back on though. Quote Link to comment Share on other sites More sharing options...
