Known inner wear issues on BMW 525 estate with runflats?
fluff34567
Hi all,
My friend has a BMW 2007 525 diesel estate with the factory run flats.
All 4 wheels are wearing on the inside, I remember an old post from Tony with a similar issue on a x5.
Are there revised settings for the 525d to reduce the wear?
 Thanks in advance.
Problem is BMW maintained the geometry positions for control at optimum speed. The issue is the RFT cannot deform and adopt the sport positions. Most times the main problem is the rear since this has the most negative camber. We simply use the camber tolerance and dial that out. Taking camber away will affect handling but only at the top end speed wise.
