NickT Posted January 31, 2019 Report Share Posted January 31, 2019 The rear camber is adjustable on the inner bolts on the lower arms. They should have adjusted both adjustments to toe and casket to set them both simultaneously. This is assuming that the rear camber adjustment is at the extreme point of adjustment of course. As Tony suggested, the rear toe / camber value is set dependant on the height between the centre of the wheel to the wheel arch. Auto data book gives a look up table for ranges on this, and not a fixed value for all. The fuel tank should ideally by half full and the boot empty. Good luck fine tuning it Quote Link to comment Share on other sites More sharing options...
jammy Posted January 31, 2019 Author Report Share Posted January 31, 2019 Mines on coilovers mate and lower than a vxr.(the machine readable the rear angles no problem.. dueit's ride height there is no more to give camber wise,and I've reduced the toe on the rear hence the camber bolt is at its full range,I can toe out 10 which will let me achieve -2 camber but the drive wasn't great. ATM these shims are the cheapest option over getting aftermarket adjustable banana arms from a focus,nothing like this is available for Vectra/signum so I'll have to start mutating parts Quote Link to comment Share on other sites More sharing options...
jammy Posted January 31, 2019 Author Report Share Posted January 31, 2019 So bloody slippery on the roads I can't tell if it's understeering or not..it is quite light on the steering though, along with having to correct it a lot. The road down this way are terrible though so going to give it a blast up the M2 Saturday.. I will get the print out up and love in a bit and see what you reckon Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 31, 2019 Report Share Posted January 31, 2019 Quote and love in a bit too much information Jammy Quote Link to comment Share on other sites More sharing options...
jammy Posted February 1, 2019 Author Report Share Posted February 1, 2019 Quote Link to comment Share on other sites More sharing options...
jammy Posted February 2, 2019 Author Report Share Posted February 2, 2019 Humpty bump Print out now addeed Quote Link to comment Share on other sites More sharing options...
jammy Posted February 2, 2019 Author Report Share Posted February 2, 2019 Also when tjer is two adults one child in The car it s EMS to drive and handle a hell of a.lot bettwr Quote Link to comment Share on other sites More sharing options...
Tony Posted February 3, 2019 Report Share Posted February 3, 2019 Print looks ok...... For a modified car the cambers are to be expected. Front/ rear camber disparity is right? Reason for the need is on turns the front cambers migrate, one lowers and one rises whereas the rear cambers just curve on transition/ bump. Quote Link to comment Share on other sites More sharing options...
jammy Posted February 3, 2019 Author Report Share Posted February 3, 2019 Going to check it tomorrow to see if anything has moved this time, hopefully it should be as it was when it left last Wednesday... Might take it back -2°00 camber and 0°10 toe? It was fine on that set up until the camber bolt worked it's way loose each time Quote Link to comment Share on other sites More sharing options...
Tony Posted February 3, 2019 Report Share Posted February 3, 2019 It will be slightly different.... Things like fuel load will be responsible... As for the settings yes mirror what worked before. Quote Link to comment Share on other sites More sharing options...
jammy Posted February 3, 2019 Author Report Share Posted February 3, 2019 Might leave the preload out this time but still have the required 30litres of diesel present? All other levels are full anyway....with the rear secure now the results maybe different this time roand? Quote Link to comment Share on other sites More sharing options...
jammy Posted February 3, 2019 Author Report Share Posted February 3, 2019 Oh yeah mi am right in saying that if it's preloaded it's 70kg a side right? Quote Link to comment Share on other sites More sharing options...
Tony Posted February 3, 2019 Report Share Posted February 3, 2019 Are you talking added ballast? Quote Link to comment Share on other sites More sharing options...
jammy Posted February 3, 2019 Author Report Share Posted February 3, 2019 Yes mate Quote Link to comment Share on other sites More sharing options...
Tony Posted February 4, 2019 Report Share Posted February 4, 2019 You only do that on OEM suspension. Quote Link to comment Share on other sites More sharing options...
jammy Posted February 4, 2019 Author Report Share Posted February 4, 2019 Ok mate will do this one with no added weight tonight and I won't put any more fuel in and see how that comes out Quote Link to comment Share on other sites More sharing options...
jammy Posted February 5, 2019 Author Report Share Posted February 5, 2019 "UPDATE" seems to have gone well..firm steering no wondering across the road, will see what it's like on a properun out up to Gatwick and back tomorrow Quote Link to comment Share on other sites More sharing options...
Tony Posted February 5, 2019 Report Share Posted February 5, 2019 Finally...... I should move this topic to "horror of the week" or year Quote Link to comment Share on other sites More sharing options...
jammy Posted February 5, 2019 Author Report Share Posted February 5, 2019 4 hours ago, Tony said: Finally...... I should move this topic to "horror of the week" or year aye it definitely qualifies I wouldn't of minded so much if it was my work that was causing the issue!! Just wish I had had enough dry time to change these driveshafts before hand but never mind. Quote Link to comment Share on other sites More sharing options...
Tony Posted February 5, 2019 Report Share Posted February 5, 2019 The shafts are a surgical fit so i doubt if it will change anything. Quote Link to comment Share on other sites More sharing options...
jammy Posted February 5, 2019 Author Report Share Posted February 5, 2019 I know when I changed the CV on the Saab 93 (same chassis and components) and that changed the toe..I'm hoping I'll manage to free the shafts without dropping the ball joints as I've got to change the speed sencors both sides which is part of the wheel bearing assembly,pretty sure I did it the same way on my first signum Quote Link to comment Share on other sites More sharing options...
jammy Posted February 5, 2019 Author Report Share Posted February 5, 2019 Steering wheel is still out a bit! Wondering if my CV joints are that shot now that it's making it do this? Quote Link to comment Share on other sites More sharing options...
Tony Posted February 5, 2019 Report Share Posted February 5, 2019 All the bits mentioned are satellites and pose no attitude to the chassis. Quote Link to comment Share on other sites More sharing options...
jammy Posted February 6, 2019 Author Report Share Posted February 6, 2019 Hmmmmmm wonder what is causing this then..hard to tell when the roads are so crap Quote Link to comment Share on other sites More sharing options...
jammy Posted February 6, 2019 Author Report Share Posted February 6, 2019 Sits a lot off to the right tbh.the steering wheel position was checked and double checked then checked again... Getting tedious now Quote Link to comment Share on other sites More sharing options...
