BMW chassis/ Alpina, sport, M-series
Just a point to note and i found this out the hard way.
BMW say on the 5 series, F10, 11, 12 and X series 4, 5, 6, 7 and 8 that the front camber angle is adjustable. Well that's not strictly true? What they do offer is a slightly longer or slightly shorter upper wishbone
Either side of the OEM wishbone the replacements offer around 30'. The points i don't like about this is
1: Cost
2: Fixed adjustment range
It's for this reason we use this type of adjuster.
This offers a progressive range + - 40'.
To the warning
All the cars listed above already use the BMW OEM -30' wishbone meaning if measured and found to need a lowering kit OEM or not the will NOT work. In addition if the replacement needed is to raise/ reduce the camber any more than 30' you will need the BMW OEM +30' longer wishbone.
