Tony Posted September 12, 2017 Author Report Share Posted September 12, 2017 Some more info Product descriptionSo In More Technical Terms, Supercharging Increases Both The Volumetric Efficiency Of The Engine And The Mass Air Flow Through The Engine To Produce Gains In Both Horsepower And Torque.Fitting Instructions PLEASE NOTE:-To Fit The Electronic Supercharger, It Would Normally Be Necessary To Remove The Cars Original Air Filter And Air Box, Which Would Normally Leave, Either An Air Intake Pipe, Or The Throttle Body Inlet. If Is An Air Intake Pipe, We Would Need To Know The Internal Diameter Of The Pipe, So As We Can Provide The Correct Fitting Adapter, If It Goes Direct On To The Throttle Body, We Would Need To Know External Diameter To Once Again Include The Correct Fitment.When The Electronic Supercharger Is Fitted On The Air Intake Side Of The Engine. The Silicone Hose May Have To Be Trimmed To A Correct Length With A Sharp Blade And Wire Cutters The Wiring Needs To Be Fitted To A Switched Or Constant Live, And The Earth Connected.The Micro Switch Needs To Be Fitted To The Throttle Linkage, Either By The Throttle Body Or Through The Bulk Head And Near To The Accelerator Pedal Being Careful Not To Put In A Position That Will Not Foul The Workings Of The Throttle Or Accelerator Pedal.Sure Up Any Loose Wiring With Cable Ties Or Electrical Tape Quote Link to comment Share on other sites More sharing options...
Rich Posted September 12, 2017 Report Share Posted September 12, 2017 How much is a charger or turbo conversion, at least £2k? Do you really think this will work the same way. Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 12, 2017 Report Share Posted September 12, 2017 Why?... Does it work the same as a supercharger, albeit low pressure? Rich the reviews are mixed although i don't understand why? Quote Link to comment Share on other sites More sharing options...
P4UL T Posted September 12, 2017 Report Share Posted September 12, 2017 Why?... Does it work the same as a supercharger, albeit low pressure? Rich the reviews are mixed although i don't understand why? As soon I saw Tony's post I was gunna wack that video up for him. I love a bit of Mighty Car Mods Quote Link to comment Share on other sites More sharing options...
NickT Posted September 12, 2017 Report Share Posted September 12, 2017 You might as well try and stick a hairdryer in its place instead Quote Link to comment Share on other sites More sharing options...
Tony Posted September 12, 2017 Author Report Share Posted September 12, 2017 Well that's quite conclusive..... I'll get me coat Quote Link to comment Share on other sites More sharing options...
Rich Posted September 12, 2017 Report Share Posted September 12, 2017 I know you don't work on engines Tony and I don't really know much about them but even I could see it was just a gimmick. Why would people pay thousands for superchargers if that would do the same thing for £100! Quote Link to comment Share on other sites More sharing options...
NickT Posted September 12, 2017 Report Share Posted September 12, 2017 But Tony knows his geometry though Quote Link to comment Share on other sites More sharing options...
Tony Posted September 13, 2017 Author Report Share Posted September 13, 2017 Indeed i do .... I was hoping for a cheap solution but it did read to good to be true hence my post. Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 13, 2017 Report Share Posted September 13, 2017 How often do you need more power ? Thought about nitrous ? Quote Link to comment Share on other sites More sharing options...
Tony Posted September 13, 2017 Author Report Share Posted September 13, 2017 I'm not looking for top end but a faster RPM would be nice. I mean it's ok really but having had a turbo i think i expected more from the engine. Quote Link to comment Share on other sites More sharing options...
NickT Posted September 13, 2017 Report Share Posted September 13, 2017 What about a remap for now? I'm sure you could get one in exchange for some geometry expertise. Quote Link to comment Share on other sites More sharing options...
Tony Posted September 14, 2017 Author Report Share Posted September 14, 2017 Can a basic 1.8 engine be mapped? Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 14, 2017 Report Share Posted September 14, 2017 Little point mapping a normally aspirated engine, you will only add 5 or 6 hp at most Quote Link to comment Share on other sites More sharing options...
Tony Posted September 14, 2017 Author Report Share Posted September 14, 2017 Oh... It was just that NickT suggested it? Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 14, 2017 Report Share Posted September 14, 2017 you can map pretty much anything but on a normally aspirated engine there is little you can do to actually add power you can only increase timing a little really and gains are minimal , its a different story on turbo charged engines Quote Link to comment Share on other sites More sharing options...
Rich Posted September 14, 2017 Report Share Posted September 14, 2017 Stop being a tightarse and get a turbo! Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 14, 2017 Report Share Posted September 14, 2017 Its an MR2 isnt it? If so you can get the Mr2 turbo engine fitted, probably best to call someone like Fensport Quote Link to comment Share on other sites More sharing options...
Tony Posted September 14, 2017 Author Report Share Posted September 14, 2017 Wouldn't a turbo fit my 1.8 VVTI engine? Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 14, 2017 Report Share Posted September 14, 2017 I'm sure you can buy a kit but thats not the cheapest way to do it Quote Link to comment Share on other sites More sharing options...
Tony Posted September 14, 2017 Author Report Share Posted September 14, 2017 I found this company which isn't far from me> http://www.pacific-works.co.uk/index.php Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 14, 2017 Report Share Posted September 14, 2017 Always best to speak to an expert Quote Link to comment Share on other sites More sharing options...
Tony Posted September 14, 2017 Author Report Share Posted September 14, 2017 That's what i thought and advice is free... Quote Link to comment Share on other sites More sharing options...
