liner33 Posted June 1, 2018 Report Share Posted June 1, 2018 That may be so but if i can find the colour then I'll do it myself. Good luck, how you can find a colour that doesn't exist outside of the paint booth of the guy who painted it I don't know. Companies will mix up paint that "looks" like the factory paint for many models , it might look like a 360, it might look like a Astra but wont match your car Quote Link to comment Share on other sites More sharing options...
Tony Posted June 1, 2018 Author Report Share Posted June 1, 2018 Did you not have paperwork with the car and it's build that might have stated the colour? Yes but the code was for the donor car. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 1, 2018 Author Report Share Posted June 1, 2018 That may be so but if i can find the colour then I'll do it myself. Good luck, how you can find a colour that doesn't exist outside of the paint booth of the guy who painted it I don't know. Companies will mix up paint that "looks" like the factory paint for many models , it might look like a 360, it might look like a Astra but wont match your car I totally agree but i have to try... Today i went to the paint company but since i was in the car he used the Ferrari colour cards to find the nearest match, he then tested the mix and then made some more with slightly more blue in the mix. I'm testing a sample now including the etch primer and clear coat...We will see? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 5, 2018 Author Report Share Posted June 5, 2018 Right i give up, it's going to the bodyshop.... I've tried four different types of Ferrari blue and none match and at £18 a can i'm done trying. Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted June 5, 2018 Report Share Posted June 5, 2018 A lesson learnt? Do you know for definite it's a Ferrari colour? Quote Link to comment Share on other sites More sharing options...
Rich Posted June 5, 2018 Report Share Posted June 5, 2018 That £72 could've paid your contents insurance! Unless it's an old banger I always think paid jobs should be left to the pros. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 5, 2018 Author Report Share Posted June 5, 2018 In hindsight yes but you have to try, i mean it could have been fine and i would have saved £100 or five? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 25, 2018 Author Report Share Posted June 25, 2018 I've been fiddling to make the fake caliper more secure and these rear spacers are the widest I've ever seen Quote Link to comment Share on other sites More sharing options...
Tony Posted June 25, 2018 Author Report Share Posted June 25, 2018 I've had to admit defeat with the paint....After can number five and £18 a can and still the colour is wrong... Next week it's going to a bodyshop to have the entire NS sprayed and blended to the sum of £600 My only consolation is the repair i did to the NSR quarter panel is invisible so at least i did something right Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted June 25, 2018 Report Share Posted June 25, 2018 Surely they have put double spacers on the back, if that's the case is it safe? Wouldn't there be too much "strain" on the long bolts? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 25, 2018 Author Report Share Posted June 25, 2018 It should be a male, female spacer so basically bolt onto hub then wheel bolt to spacer.....Still the biggest I've seen but to get the correct dimensions of the 360 there's no other way. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 25, 2018 Report Share Posted June 25, 2018 Does having spacers that big affect the handling? Have you driven a stock MR2 to compare? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 25, 2018 Author Report Share Posted June 25, 2018 A wide track at the rear should improve the handling, it's the front spacers that are an issue. Quote Link to comment Share on other sites More sharing options...
liner33 Posted June 26, 2018 Report Share Posted June 26, 2018 Those discs look like they need changing as well. From an engineering point of view thats shocking , really don't like it just as well you wont be going very fast Quote Link to comment Share on other sites More sharing options...
Tony Posted June 26, 2018 Author Report Share Posted June 26, 2018 Problem is the pads are not full contact... Pads and the working disc area are fine. There's no lip on the discs just cosmetic surface rust. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 28, 2018 Author Report Share Posted June 28, 2018 Nearly there...The car goes to the bodyshop Monday for a week. The entire NS needs preping and then painting. Unlike the paint I've used they are using a water based paint. The fact only a small part was marked by me they have to do one side of the car so that the paint blends in... Assuming it is a good match i'm going to ask for a small tin of paint so i can tidy up and paint other blemishes but only small areas using this... Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted June 28, 2018 Report Share Posted June 28, 2018 Isn't that for doing finger nails Quote Link to comment Share on other sites More sharing options...
Tony Posted June 28, 2018 Author Report Share Posted June 28, 2018 Yes it's a very fine mist which i think will do just fine for the small areas i'm addressing. I'm talking chip, scratch, crack. If i could get a paint pen or chip stick i would but there's no match out there i can use. So all things working well if they can match the paint these small areas i can do myself.... Next week is going to cost me £600 and even after that i need the bonnet done because the finish is terrible f-ck knows what DNA were thinking?... Slightly off topic i'm about to insure the car again and the registration lists the car as DNA3 so there's no mistaking the build. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 30, 2018 Author Report Share Posted June 30, 2018 I've fitted alloy covers on the dash. Often i see this on the F430 and although I've not seen a F360 with this type of dash i know they do make them... Cost isn't to bad but they do come from the US so it's a slow process. Apart from the look it does brake up the black OEM dash so elevating the look away from the MR2. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 2, 2018 Author Report Share Posted July 2, 2018 Cars in the bodyshop now but what trauma it was getting there?....Elaine knew a way into Berkhamsted but without having to drive into the town centre since the car has trouble on the speed humps. So plan was follow her, drop the car off and a lift home, sounds simple "you would think!".. I followed her on the bypass totally aware i don't know where i'm going. A mile or so in she pulled out to the fast lane with me close behind, but then we were hitting 60mph, 70, 80, 90. I'm thinking bloody slow down woman. After miles of fast lane then back to the inside lane I'm beginning to wonder where the hell is she taking me. As the road signs flew past with names i recognize as miles past where i though we was going i pulled over..... I called her saying "what the fu&k are you doing!"... Only to be told i was following the wrong BMW....He must have thought i wanted to race....So i did a U-turn in the country lane and got beached on a pothole ....A good 30min trying the rock the car off/ out of the hole with much scraping and crunching i got out..... What are the odds on a black 3 series BMW in front of Elaine and me thinking it was her...The driver must have thought i was some posh idiot wanting a race in rush hour traffic... Quote Link to comment Share on other sites More sharing options...
Rich Posted July 2, 2018 Report Share Posted July 2, 2018 pmsl, that could only happen to you! Did you not recognise the numberplate on the BMW then? Must've been a deep pothole to get stuck on it? Quote Link to comment Share on other sites More sharing options...
Tony Posted July 2, 2018 Author Report Share Posted July 2, 2018 I didn't get a chance to read the plate but at the time i thought it was her... A whole set of conditions and chance lead to what happened. The BMW was a black three series same as her's. It pulled out into the fast lane from in front of Elaine and i initially wasn't expecting to know where i was going hence the reason i was following her. The pot-hole was the exact reason why i didn't want to drive down the town centre. This one was more like a hole in a hole and it was an off-road parking area. I though it must have damaged the sills since i could hear them crunching but on inspection they are fine. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 6, 2018 Author Report Share Posted July 6, 2018 Please to say the cars been in the bodyshop and the paint blend is excellent. One area where i went totally wrong is the paint is water based not oil based. The water base initially looks totally wrong until the water has evaporated and then a clear coat locks everything in. It wasn't exactly cheap at £600 but it was worth it to me. Next to do is get them to spay the bonnet, reason being the paint on it is to thin so i can see the waive and they quoted me £300 for that. Quote Link to comment Share on other sites More sharing options...
Rich Posted July 6, 2018 Report Share Posted July 6, 2018 Looks like they did a great job Why didn't you just get them to do the bonnet at the same time? Quote Link to comment Share on other sites More sharing options...
Tony Posted July 6, 2018 Author Report Share Posted July 6, 2018 Couldn't really go a grand in one hit... I have the money but the car i have a budget on. Quote Link to comment Share on other sites More sharing options...
