liner33
Jaguar XF-R MY2012 5.0
yep i have to say i havent fitted the one in the prius yet , need to do some research first
Share this post
Link to post
I fitted one in the Focus, down the door trim and out under the seat and plugged into the back 12V socket. So easy and you can't see the wiring.
Share this post
Link to post
Thought i'd post a few mid detail pics on here rather than the Octavia thread, still have the wheels to do along with the windscreen and front bumper
Polished with Carpro Reflect, two coats of Jetseal and two coats of Petes 53 wax , will add two coats of Zaino Z8 tomorrow , same on all the glass apart from windscreen
Share this post
Link to post
Niiiiiiice :)
You planning on tinting the windows at all?
I'm not sure , I'm thinking not , there is a electric rear blind so it should stay cooler in summer and my window tinter wont thank me as the rear window will be a sod to do
Share this post
Link to post
I have bought some new wheels , bit of a bargain on ebay but not 100% sure they will fit yet , they are off a Jag XK and dont have TPMS sensors unlike my car so whether A) I can fit sensors to these wheels and B) How easy it will be to get them coded or preferable cloned,  time will tell
Share this post
Link to post
Just move them to the correct wheels, there shouldn't be any problems.
Share this post
Link to post
I'm not sure the tpms valve will fit in the same place as a normal rubber valve ,
Share this post
Link to post
TPM will fit fine and as said be sure the right valve goes to the same side NSF /OSF/ NSR/ OSR
Share this post
Link to post
Dont think it matters on this car. Apparently there is an aerial above each wheel which picks up the signal from the tpms , you dont need to code them or anything so i will just buy 4 new ones and fit them to these wheels
Share this post
Link to post
As you must know then some TPM systems display which tyre is soft whereas your type is more globule.
Share this post
Link to post
Yeah the 370 had to be coded to a specific location although on the dash it didnt indicate which tyre was low but i'm assured thats not the case with these
Share this post
Link to post
yes but i have the fronts and rears fitted where they should be . The fronts are fine
Share this post
Link to post
