Rich's 1999 MX5 1.8i S
This was before I changed the calipers, I'm hoping the new ones have fixed the problem but it was the OS that seized not the NS.
If it was pulling to the right then the offside caliper was working but the nearside not so much hence the pull in that direction
Share this post
Link to post
Maybe that's highlighted in the pad thickness. The OS caliper seemed to be ok until it seized and I only did a mile back home so it wouldn't of worn that much material. The NS pads have more meat so you must be right and that caliper wasn't working efficiently.
I've just been on a 20 mile run and braked heavy a few times. It didn't pull to the right anymore although was a little squirmy but I put that down to the soft Toyo tyres.
Going to WIM soon to get the fluid changed so hopefully once that's done and the pads have bedded in the brakes will be a lot better. I picked up 2 X 1 litre bottles of Pagid dot 4 for a tenner. Great price! :)
Share this post
Link to post
Brakes sorted :) Hopefully the tyres will stop going flat now the leaky valves have been sorted.
I've decided I'm going to drill 2 small holes where the battery sits so the water can drain away. Otherwise it will carry on rusting and eventually I'll need that welded up. To remove the bumper I need to take the numberplate off which is stuck on so need some new stickers first. Hopefully I can trace the leak and get it sorted.
Next main job will be those rusty rear sills which I'm hoping to get done asap. Then it'll be ready for the summer!
Share this post
Link to post
They are well known for rusting the sills. Are you going to replace them or just have them welded.
Share this post
Link to post
The guy doing it said he'll cut the rot out and fabricate some new panels. You can buy repair panels but he said you end up trimming so much off a lot of it goes in the bin. Plus he'd use thicker metal than what they're made of.
Went for a drive earlier to pick Josh up from school. Roof down on the way, really love this car! :D
Share this post
Link to post
He sounds confident with the fix which is very good.....It's amazing how the winter chills and damp soft top dissolve away with the roof down on a hot day.
Share this post
Link to post
Hoping to get it down there next week and get the sills done, they're looking pretty bad now!
The battery cut off switch I fitted is really good. Last used the car 2 weeks a go and it started first time earlier with no hesitation. If I had left it connected it would've struggled or needed a jump start. After 2 weeks of using the BMW it was a shock with the road noise!! :lol:
I think I need to replace the clutch slave cylinder too. The pedal feels quite light and still squeaks and for what it costs I might as well do that first.
Share this post
Link to post
I take it you never found out what the drain was?......Another point if the battery is disarmed does that include the alarm?
Share this post
Link to post
The drain is lack of use!! There isn't an alarm on the car so no worries there.
Share this post
Link to post
Oh i see....It's just they don't all drain the battery hence the reason i thought alarm or immobilizer.
Share this post
Link to post
Don't use a car for more than 3 weeks and they'll all struggle. The battery has been flat a few times now which doesn't help.
Share this post
Link to post
Saying that my 360 battery goes flat after a few weeks and i don't even turn the alarm on.
Share this post
Link to post
Finally got the car back tonight, really missed it! :D He took a couple of photos of the work while he did it. End result looks great but it needs a good clean and then I'll take some.
This was the worse side and needed a repair panel. The other side wasn't that bad so he cut the rot out and welded some fresh metal in taken from a scrap transit van!
Share this post
Link to post
Will be good to see it all merged in. Hard to imagine how they get it all flattened into one but they do.
Share this post
Link to post
It looks like he's done a great job. He's always very busy and he had the car over 3 months as other work had to take priority. He's a friend of my Dad's so he was doing it when he was free.
Going to drive it this week and then it's coming off the road for winter. Although if the weather stays like this I might do it the end of November.
I wasn't going to use it until I had protected what he'd done but he has filled the sills with waxoyl already :)
Share this post
Link to post
Thats a decent bit of fabrication from what i can see on the pics! I'd pay particular attention to the rear arches where water rolls down and off the sill - its just a natrual place for water to sit. If its clean as a whistle - i'd ensure theres a nice smooth runoff gradient using some seam sealer etc (no places for water to sit and pool up) and also protect the hell out of that area with dinitrol or waxoyl after and keep clean religiously thereafter. I always spend a good amount of time with a hose and run my hands all up on my arch lips and clean them throughly every time i wash (snow foam).
Also make sure your drain holes are clear post work - its common for these to get blocked up with waxoyl etc if the chap doesn't know they are there.
Worth manage expectations that this is not a forever fix - you'll get 5 years or so out of it before it'll need another look unless its stored inside in a nice warm garage. I think mines about 4 years in and i know its going to need some love again in the next couple of years to keep on top of it.
Share this post
Link to post
I'm going to Bilt Hamber the whole area in the spring so hopefully that'll offer some more protection but yes I'll be making sure the arch lips are cleaned regularly.
Good tip with the drain holes. I did check they were still there as I know some people weld the holes shut! I'll make sure they're clear.
As I won't be using it in the winter hopefully it'll last longer than 5 years. Considering this was the first repair it's had in 19 years it hasn't done too badly.
I just need to find the leak in the boot now as it keeps running in to the battery well. I'll probably drill a small hole in each recess where the tray sits so at least the water can't sit there rusting the area!
Share this post
Link to post
Nice bit of work there :) looking forward to seeing it when it’s done!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
