littlebrownbike Posted August 25, 2014 Report Share Posted August 25, 2014 Normally I use a garage with a Hunter DSP600, however I've found one closer but they use a Beissbarth 4-wheel alignment system. Is this as good or is it best to stick with a place with a Hunter machine? Cheers Quote Link to comment Share on other sites More sharing options...
Tony Posted August 26, 2014 Report Share Posted August 26, 2014 The Hunter gathers more information whereas the Beissbarth is marked for the German range by association it being German made machine. Quote Link to comment Share on other sites More sharing options...
littlebrownbike Posted August 26, 2014 Author Report Share Posted August 26, 2014 The garage in question is a Porsche specialist and my car is a Cayman, do you think I'll get the correct results from it or should I stick with a hunter? Quote Link to comment Share on other sites More sharing options...
Tony Posted August 27, 2014 Report Share Posted August 27, 2014 I think be guided by price unless there's handling issues then the Hunters information gathering is the better option. Quote Link to comment Share on other sites More sharing options...
littlebrownbike Posted August 27, 2014 Author Report Share Posted August 27, 2014 Just the steering wheel isn't straight. Admittedly I thought it would be either 'it is suited to the task' or 'it isn't'. The tyres are 19" and quite expensive, better play it safe and just go for the Hunter. Quote Link to comment Share on other sites More sharing options...
littlebrownbike Posted August 27, 2014 Author Report Share Posted August 27, 2014 P.S. CHeers :-) Quote Link to comment Share on other sites More sharing options...
Tony Posted August 28, 2014 Report Share Posted August 28, 2014 What happened between it being straight and now? Quote Link to comment Share on other sites More sharing options...
littlebrownbike Posted August 28, 2014 Author Report Share Posted August 28, 2014 Not sure, I bought the car like this. I've done about 1500 miles in it and the tyres have done about 2000 miles. Quote Link to comment Share on other sites More sharing options...
Tony Posted August 28, 2014 Report Share Posted August 28, 2014 A geo is the way to go then, please make sure they measure the castor angle and they give you a full printout. Quote Link to comment Share on other sites More sharing options...
littlebrownbike Posted August 28, 2014 Author Report Share Posted August 28, 2014 Most certainly, the question is will a Beissbarth do this? Quote Link to comment Share on other sites More sharing options...
Tony Posted August 28, 2014 Report Share Posted August 28, 2014 Yes it will but because it's not adjustable on your car most technicians don't bother to measure it. Quote Link to comment Share on other sites More sharing options...
