Rich Posted January 6, 2020 Author Report Share Posted January 6, 2020 It was ok on the 5 mile drive to work this morning, apart from the dodgy gear changes between 1st and 2nd (which I think is a solenoid issue). The car is level to the eye but I haven't measured the arch gap yet. Both springs are there on the rear and I can't move them, they don't feel loose. Mind you if the top coil had snapped off the tension probably means I couldn't move it anyway? The sound was like a shotgun going off or something popping back in to place. Definitely wasn't from the dryer. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 6, 2020 Report Share Posted January 6, 2020 They normally snap on the top or bottom helix... Apart from the height all that would change is the coils pre-load. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 6, 2020 Author Report Share Posted January 6, 2020 Doing the finger test on flat level ground I can get 3 in each arch gap but the OSR is slightly tighter than the NSR. The car drives fine though and I can't feel any difference. I'll see if I can get it jacked up at the weekend although I won't have much time. It was so much easier having a day off in the week! If I do notice the end has snapped are they easy to replace? Do you clamp the springs with the car down, undo the shock bolt and then raise the car to remove it? Quote Link to comment Share on other sites More sharing options...
Geoffers Posted January 6, 2020 Report Share Posted January 6, 2020 Could something have hit the car? I mean like a nut dropped from a bird or something? Makes a hell of a crack. Or maybe something kicked up by a vehicle in another carriageway? Field nearby with farm machinery in? In Formby up here loads of people complain about their cars being hit by farm machinery kicking stuff out of the fields. Just guessing obv. hoping it's nothing to do with your car. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 7, 2020 Report Share Posted January 7, 2020 If they are OEM coils and not lowering coils then they will need compressing..... Saying that on some cars if to undo the damper and then jack the car up then the damper length will remove the load. If the bottom of the damper is fork shaped then they are an arse to remove/ fit. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 9, 2020 Author Report Share Posted January 9, 2020 I've had things hit the car before - stones, a pigeon etc and while the noise has been loud it was more of a dull thud than this bang. It was like it came from within the car so with the position of the springs it could've been those. It's still driving fine so I'll check them when I get the chance. I remember buying some Mondeo struts once that came off a daily runner when it was being broken. I only wanted the springs but on one of them the coil had snapped at the top. I told the guy I bought them from and he had no idea at all that he'd been driving with it broken. I've been looking online for a DIY guide Tony but can't find any. My concern is I undo the shock and the spring pops out! It's not fork shaped and looks like this: Quote Link to comment Share on other sites More sharing options...
Tony Posted January 9, 2020 Report Share Posted January 9, 2020 Use a jack to remove the tension.... You'll know it's safe if you can just pull the lower damper bolt. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 10, 2020 Author Report Share Posted January 10, 2020 Ok thanks, will take a look and see if they're broken first. The FIL changed the ones on his Fiesta yesterday that has the same setup. He said he removed the shock first (he was replacing that too) and then compressed the spring to remove that. I also smelt eggy farts from the exhaust again, I smelt it before Xmas but was hoping it was a one off. So my CAT is probably on the way out! Quote Link to comment Share on other sites More sharing options...
Rich Posted October 31, 2020 Author Report Share Posted October 31, 2020 Well I never did find out what that noise was! Passed the MOT today and they didn't spot anything like a broken spring. Drives fine too. I had to fit a new battery a few weeks a go as it seems my short journeys were killing the other one. After leaving the car for 2 days it would struggle to start. I really need to start taking it for longer runs now and again to keep the battery charger. Also a big thanks to @Geoffers for some advice he has given me when it came to testing the battery. I also did the oil change last week, 3 years since the last one!! I have only done 5k miles but it was black so lesson learnt. I have also switched to 5w40 from 5w30 to see if it helps with the amount it uses. 1 Quote Link to comment Share on other sites More sharing options...
Rich Posted December 17, 2020 Author Report Share Posted December 17, 2020 So I got to work earlier and as I got out of the car I was met by that familiar smell of binding brakes! It's been 5 years since I replaced the rear calipers and hoses so I'm hoping they just need a clean up and it's not the piston! My low mileage is definitely not helping! It's a good job I'm off work for 2 weeks after today. Quote Link to comment Share on other sites More sharing options...
Tony Posted December 17, 2020 Report Share Posted December 17, 2020 Put the back of your hand on the wheels to find out which brake is the problem. Quote Link to comment Share on other sites More sharing options...
Rich Posted December 17, 2020 Author Report Share Posted December 17, 2020 That was the first thing I did although I knew which wheel it would be. I've been smelling a slight heat smell after a spirited drive but it wasn't a binding brake one so assumed it was just working hard. The wheels were never hot to touch. There are a couple of flooded areas on the way to work, plus the usual spray and with the rear being quite exposed the brakes get hammered. TBH I was surprised they lasted 5 years without me needing to clean them up again. Hopefully it's just the slider pins and general crap. I just need to try and drive the car home now but it's only 5 miles so should make it! Quote Link to comment Share on other sites More sharing options...
Rich Posted December 18, 2020 Author Report Share Posted December 18, 2020 Took it easy going home yesterday, mainly 30 limits with a short 60 stretch and used minimal braking. The wheel was cold when I got home and no smell. So hopefully I've caught it early and nothing is badly seized. Just a pain having to do it in this weather! Quote Link to comment Share on other sites More sharing options...
Rich Posted October 29, 2021 Author Report Share Posted October 29, 2021 You know what, I can't remember if I actually cleaned the rear brakes up from my last post but they've been fine since! Passed the MOT on Wednesday. Despite some battle scars on the bodywork he said the car mechanically is in great condition. I did 155 miles, mainly at 50-70mph on motorways and dual carriageways. This only returned 23mpg, which is down a little. Usually it would do 26-27 on a trip like that. That cost me £40 with petrol now being £1.46 a litre! ☹️ The oil change is due, which I'll be doing in a couple of weeks and I'll replace the air filter. I've only done 2k miles in the last year. I changed the oil to 5w40 last year which has been ok but I'm now going to switch to 0w30. A 20L bottle is just under £70 delivered (with a code) and will do me for 4 years. 5L bottles are £26+, even more from places like ECP, so it'll leave me plenty for top ups too. https://www.lubetechshop.co.uk/product/optima-fs-0w30-fully-synthetic-engine-oil-acea-a5-b5-a1-b1-api-sl-cf/ Quote Link to comment Share on other sites More sharing options...
adam_r Posted October 29, 2021 Report Share Posted October 29, 2021 Rich, fuel economy drop is due to E10 fuel... I have dropped atleast 50-80 miles range from a full tank.. That is over the past 4 tanks with normal driving so I know its not a heavy footed issue Quote Link to comment Share on other sites More sharing options...
Rich Posted October 29, 2021 Author Report Share Posted October 29, 2021 Would it really drop that much? That's not good in a 2.4L petrol! They are determined to get petrol and diesel cars off the road aren't they. I've switched to Esso E0 in the MX5 but I doubt it's worth it for the Accord. The extra price paid for Supreme fuel won't give me that many more miles. Maybe I should try a tankful and see though. Quote Link to comment Share on other sites More sharing options...
liner33 Posted October 29, 2021 Report Share Posted October 29, 2021 Yep my little Up has dropped almost 10 mpg since the swap to e10 Quote Link to comment Share on other sites More sharing options...
Rich Posted October 29, 2021 Author Report Share Posted October 29, 2021 That's just bonkers! I've only put petrol in the Accord twice since the change and not even a full tank. I do 10 miles a day going to work and back so didn't notice any difference the first time but I did on Wednesday when I was literally watching the fuel guage drop like a stone! Quote Link to comment Share on other sites More sharing options...
Rich Posted November 16, 2021 Author Report Share Posted November 16, 2021 Well I put some v power in the car, 24 litres costing £40. I got 95 miles from it which is about 18mpg! I checked my invoices earlier to see when I gave it a full service with plugs etc, it was in 2014 at 100k miles. It's done 130k miles now. The plugs should be replaced at 25k mile intervals, the auto gearbox oil at 50k miles or 4 years, so it's 7 years old. Then the air filter and oil. I'm going to order everything and get it done. The first coolant change was also due 5k miles a go so that should be ok. It has been losing it gradually for a few years so I just top it up. The car has only done 5k miles in the last 5 years so I'm trying not to spend too much on it. Especially when it's only worth £500 now. It won't be long before the tax costs more than what it's worth! Quote Link to comment Share on other sites More sharing options...
