SHAHZ Posted April 7, 2015 Author Report Share Posted April 7, 2015 Nothing a javelin through the neck won't cure Or that will do it!! Quote Link to comment Share on other sites More sharing options...
SHAHZ Posted April 7, 2015 Author Report Share Posted April 7, 2015 Blimey she scrubs up well....Makes me want to clean our BMW, problem is Elaine s cat has taken to sitting on the bonnet Do it, didnt take more than 20 minutes! next time it should be even easier (next time this is me ) Quote Link to comment Share on other sites More sharing options...
Tony Posted April 7, 2015 Report Share Posted April 7, 2015 Nothing a javelin through the neck won't cure Or that will do it!! My thoughts exactly Quote Link to comment Share on other sites More sharing options...
SHAHZ Posted June 3, 2015 Author Report Share Posted June 3, 2015 Well the car is now out of warranty and so this service was done by my usual Indy garage! This lot turned up a few days ago Oil drained and refilled Plugs being changed They were quite a state! Look like they have never been changed, so much for a full BMW service history!! Car feels so much smoother now Quote Link to comment Share on other sites More sharing options...
parthiban Posted June 3, 2015 Report Share Posted June 3, 2015 Wow plugs look bad! Although given them putting the wrong plugs in my brother's BMW perhaps this was a better option! Quote Link to comment Share on other sites More sharing options...
Rich Posted June 3, 2015 Report Share Posted June 3, 2015 I missed the last update, was away then. You did a good job on the engine bay Plugs look bad, have they made any difference? Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted June 3, 2015 Report Share Posted June 3, 2015 So at least two of the plus are running black - either too rich or oil - did they investigate? Quote Link to comment Share on other sites More sharing options...
SHAHZ Posted June 3, 2015 Author Report Share Posted June 3, 2015 Wow plugs look bad! Although given them putting the wrong plugs in my brother's BMW perhaps this was a better option! Given that it's got full bm service history till this point @ 100k and the plugs have not been changed is also worrying! As the plugs were not changed at the last service thought I better check the service book to see when they where done last as they are meant to be done every 3rd service! I missed the last update, was away then. You did a good job on the engine bay Plugs look bad, have they made any difference? Cheers Rich, going to give it another clean soon and try and keep on top of it, makes it easier to keep clean then! Running so much better with the new plugs! So at least two of the plus are running black - either too rich or oil - did they investigate? At the moment I'm putting it down to the dirty air filter and the fact that they have never been changed! Will be due for another service in October so will check them again then Quote Link to comment Share on other sites More sharing options...
liner33 Posted June 4, 2015 Report Share Posted June 4, 2015 I very much doubt those plugs have done 100k , I'd recommend running a high detergent fuel like v power or an injection cleaner for a while Quote Link to comment Share on other sites More sharing options...
Tony Posted June 4, 2015 Report Share Posted June 4, 2015 I second that.... Quote Link to comment Share on other sites More sharing options...
SHAHZ Posted June 4, 2015 Author Report Share Posted June 4, 2015 I based it on what they look like as well as the service book shows no change of sparks! However will be guided by you guys; ive only ever run ot on Vpower since ive had it so tick in that box - always been a bit sceptical about running any fuel additives, dont know why just have a feeling that it will make it run poorly - any recommendations on which to use? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 4, 2015 Report Share Posted June 4, 2015 Whatever you use make sure it cleans the injectors as well..... Oh and from your records has the fuel filter ever been changed? Quote Link to comment Share on other sites More sharing options...
liner33 Posted June 4, 2015 Report Share Posted June 4, 2015 I based it on what they look like as well as the service book shows no change of sparks! However will be guided by you guys; ive only ever run ot on Vpower since ive had it so tick in that box - always been a bit sceptical about running any fuel additives, dont know why just have a feeling that it will make it run poorly - any recommendations on which to use? They can remove the build up in injectors only really useful on higher mileage stuff , looking at those plugs as mentioned two are a little sooty , perhaps they werent sparking properly or perhaps the injectors arent atomising very well , you've solved the former and some injector cleaner will help the latter (As will a Terraclean treatment) I've always had good results with this brand http://www.stp.com/products/fuel-additives/super-concentrated-fuel-injector-cleaner/ Halfords used to stock it In fact they still do , i'd be tempted to run two or three tankfuls with some in , for the cost its got to be worth a try http://www.halfords.com/motoring-travel/engine-oils-fluids/fuel-oil-additives/stp-petrol-injector-cleaner-200ml Quote Link to comment Share on other sites More sharing options...
SHAHZ Posted June 4, 2015 Author Report Share Posted June 4, 2015 Whatever you use make sure it cleans the injectors as well..... Oh and from your records has the fuel filter ever been changed? Not as far as im aware, when i spoke to BMW the other day to order the parts i asked for the fuel filter and the guy said the filter is in the fuel tank and these dont normally get changed?! I based it on what they look like as well as the service book shows no change of sparks! However will be guided by you guys; ive only ever run ot on Vpower since ive had it so tick in that box - always been a bit sceptical about running any fuel additives, dont know why just have a feeling that it will make it run poorly - any recommendations on which to use? They can remove the build up in injectors only really useful on higher mileage stuff , looking at those plugs as mentioned two are a little sooty , perhaps they werent sparking properly or perhaps the injectors arent atomising very well , you've solved the former and some injector cleaner will help the latter (As will a Terraclean treatment) I've always had good results with this brand http://www.stp.com/products/fuel-additives/super-concentrated-fuel-injector-cleaner/ Halfords used to stock it In fact they still do , i'd be tempted to run two or three tankfuls with some in , for the cost its got to be worth a try http://www.halfords.com/motoring-travel/engine-oils-fluids/fuel-oil-additives/stp-petrol-injector-cleaner-200ml So are you saying to use both the STP and terraclean? as you say at the cost might aswell run a few tanks! Quote Link to comment Share on other sites More sharing options...
liner33 Posted June 4, 2015 Report Share Posted June 4, 2015 Stp first , Terraclean is £150 Quote Link to comment Share on other sites More sharing options...
SHAHZ Posted June 4, 2015 Author Report Share Posted June 4, 2015 Loool, just a little price difference Quote Link to comment Share on other sites More sharing options...
SHAHZ Posted June 15, 2015 Author Report Share Posted June 15, 2015 Car went straight on to the ramp when i arrived @ WIM HQMv2s went straight into the rental to bring home!Upon collection, this is how she looked!However it was rubbing on the rears so had to go back up a bit and is sitting like this at the momentI now need to try and get some details on the pre load as Joe wasnt sure as to what this should be, having had a quick look around on the web it seems that 4mm seems to be a standard set up, however will contact BC to see if they can shed any light!Very pleased with the look, however does feel a little bouncy! will be trying to get Phil from Arch enemy down to wim when i have my fine tune and can hopefully bring it back down again.... fronts certainly need more drop, but i thought would leave it where it is while its bedding in! Quote Link to comment Share on other sites More sharing options...
adam_r Posted June 15, 2015 Report Share Posted June 15, 2015 1 word: GANGSTA! Quote Link to comment Share on other sites More sharing options...
parthiban Posted June 15, 2015 Report Share Posted June 15, 2015 Wow, that looks amazing! Love the curve on the rears Can't wait to see this in the flesh (hopefully when it's still clean ). Interesting that it feels so bouncy, is the new set up a lot firmer? (I'm assuming you're feeling the bounce in the road rather than the suspension actually being bouncier?) Quote Link to comment Share on other sites More sharing options...
SHAHZ Posted June 15, 2015 Author Report Share Posted June 15, 2015 Wow, that looks amazing! Love the curve on the rears Can't wait to see this in the flesh (hopefully when it's still clean ). Interesting that it feels so bouncy, is the new set up a lot firmer? (I'm assuming you're feeling the bounce in the road rather than the suspension actually being bouncier?) Cheers lads The concave is why i love these wheels and wanted the 9.5j on the front, as you can see you dont get the deep concave with the 8.5j : might get some spacers on the front to bring them out a touch! The more im driving the more im getting the feeling that this is what it is (bounce on road), ive never really understood the preload stuff, but essentially this could be part of the reason, but am now also thinking that its because the damper is set towards hard, might need to soften them a bit! Quote Link to comment Share on other sites More sharing options...
parthiban Posted June 15, 2015 Report Share Posted June 15, 2015 I actually prefer it when the rear wheels clearly look wider than the fronts, makes it look more aggressive on a RWD car - might just be me being weird though Given that it used to be on runflats and BMW sports suspension it must be really firm now! As the wheels are so much bigger you probably want more compliant suspension, interested to see if softening the dampers sorts it. Hopefully we can try and sort the mini meet when you go in for the fine tune! Quote Link to comment Share on other sites More sharing options...
SHAHZ Posted June 15, 2015 Author Report Share Posted June 15, 2015 Yeah so do I actually, it's just I wanted the deep concave all round and the curves look so much better! I hope so, it's actually making me feel a little giddy! Will turn the dampers a couple of notches tonight and see how that goes tomorrow! Yeap, will let everyone know on the other thread when I'm going back! Quote Link to comment Share on other sites More sharing options...
SHAHZ Posted June 15, 2015 Author Report Share Posted June 15, 2015 Oops double post! Quote Link to comment Share on other sites More sharing options...
parthiban Posted June 15, 2015 Report Share Posted June 15, 2015 Lol at feeling giddy I definitely know what you mean by the bouncy feeling, when I stick the 360 in sport mode (which stiffens the dampers) on a poor road I get the exact same bouncy feeling, switch it off and it goes away. It sounds like the same issue for you so hopefully that should sort it. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 16, 2015 Report Share Posted June 16, 2015 The car looks good mate, really aggressive Is the bouncing when going over bumps and dips in the road, rather than smoothly going over them? Is the ride very firm? This sounds like what happened with S2IMs MX5 when the BCRs were fitted and that was down to the preload needing adjusting. Quote Link to comment Share on other sites More sharing options...
