My E60 530i
SHAHZ
It will come...... Fact is though it would take one hell of a mess to make your car look dirty.
It doesn't look so great at the moment, I've had it out in the rain a few times recently and it's a bit filthy (rather embarrassingly!)
I need to get Shahz round to sort it out  :D
  • Replies 273
Posted Images
  • 3 weeks later...
Typical! Last weekend got in the car to go get my MOT.... Bong, front side light blown :lol:
Still passed and I ordered a new set, the replacement sent under warranty a while ago were crap anyway so went for some different ones
Big heat sink!
Didn't think it would fit, but it's a perfect fit!
Left side changed
Both bulbs replaced
Can't really tell on the pics, but they are visibly brighter than that last set!
One of my xenons has also blown, replacement bulbs arrived today and need to get them fitted!
Big heat sink!
That is a huge heatsink! Looks great  :)
@ Rich I'm assuming he has a friendly MOT tester  :D
The same as mine then :whistle:  he probably would've let that slide as he knows I'd change it immediately.
They are an easy fit. On some cars it could take over an hour just to fit a bulb.
The headlight won't be as easy, the whole lamp will need to come out!
How did it pass with a side light blown?
They look great, I bet you get flashed by oncoming drivers now! :whistle:
He knows I'd replace it, and as Tony says, it was working at the time of the test.... No way to prove it wasn't! I remember on the Lexus when one of the shocks was leaking, he passed it but put the miles around 200 less on the on the mot then it was to cover himself!
Big heat sink!
Friggin massive, when I saw it I thought there's no way it would fit!
  • 1 year later...
So it's been quite some time since I've done an update, so here goes...
Headlight blew so had to get a replacement, bit of a PIAas the whole lamp needs to come out, replaced the pair
Old out
New in
Not long after, it was running really rough at high speeds, all 6 coil packs replaced
December 2015, I came out to this
What was left of the barrel
They had unlocked the car, however luckily my car has had the security update that prevents the windows from being rolled down, if it had, they could have reached down to the OBD port without the alarm going off and reprogrammed another key!
Passenger side door handles don't have key holes, my solution, I got a right side door handle from a left hand drive car
As I was getting the carrier sprayed, I got my wing mirrors redone as they where covered in chips
While I was at it, I thought I might as well
It's been sat there for a while, only fitted it a few weeks back :lol:
Tail end of last year, the car started running rough on cold starts, smoke test showed the rocker cover was cracked!
Whilst this helped, it soon was running rough again in cold starts which is now indicating injectors as the coils and plugs have been changed; still haven't got round to getting them changed.
Also, last week I have noticed a bit of coolant leaking by one of the pipes, I think the pipe needs replacing!
As my wheels hadn't been put back on last year, I washed and sealed them 654BA727-C2BF-417A-A414-18A23F026216.jpg
Gave the car a good wash
And put the wheels back on :)
Couple of them do need a refurb, will try and get them done over the summer !
As i was putting them back on, i found one of the front bolts wouldn't tighten, so i think it has threaded, I've left it for now as i was running on 4 bolts all round on the winters as i couldn't find the locking nut!
Bummer about the attempted theft, just as well you had extra security. The rocker cover is odd, has someone tried to tighten it?.... Needless to say the final look is stunning so well done :smile_anim:
Still looking good !
Had the same idea re -door handles on my Skyline , I replaced both sides with the ones from the rear doors of the 4 door models , no key holes . Fitted a switch in the boot that popped the door on the drivers side if the remote locking failed
Thanks gents!
Not sure on the rocker cover, may well have been! Nope no key hole on either side!
Got this fitted too
Comes with proximity / shock sensors, immobiliser and OBD immobiliser
Quick vid of the prox sensor
http://rs780.pbsrc.com/albums/yy86/AIYA_Z/Car/82B33940-969D-46F2-8395-CFE872E2861A_1.mp4?w=160&h=160&fit=clip
  • 4 weeks later...
Got the coolant leak sorted, it was a 3 way pipe that comes from the expansion tank that was leaking, here's the old one.
Got a service too
Still have the issue of the cold starts to sort, he cleaned the engine solenoid and said to see if it makes any difference, I suspect it won't and will need new injectors, will find out tomorrow!!
