Zeemo Posted August 29, 2021 Report Share Posted August 29, 2021 16 hours ago, SMARTLY said: Swap wheels and tyres on front around to see if the pull changes side There are new tyres fitted wheels swapped, all suspension components done.. The only thing i have in mind right now is the steering angle sensor is slightly off. Its not the pull because when steering wheel is striaght the car goes nicely straight.. Its the steering wheel going a couple degrees anticlockwise. Im not sure if but dont think it would caise the power steering to move the steering with a tiny force enough to cause this Quote Link to comment Share on other sites More sharing options...
Rich Posted August 29, 2021 Report Share Posted August 29, 2021 If they're new tyres have a read of this. https://www.wheels-inmotion.co.uk/forum/index.php?/topic/165-new-tyres-and-their-markings/ Swap the front wheels over with eachother and see if it pulls the other way. If it does then it's the tyres causing it. Quote Link to comment Share on other sites More sharing options...
Tony Posted August 30, 2021 Report Share Posted August 30, 2021 Just to note if the pull stops when the tyres are swapped over it's not a fault, just a build issue. The steering angle sensor can be reset via the ecu. The steering angle sensor is telling the car where forward is. Quote Link to comment Share on other sites More sharing options...
Zeemo Posted September 7, 2021 Report Share Posted September 7, 2021 On 30/08/2021 at 10:30, Tony said: Just to note if the pull stops when the tyres are swapped over it's not a fault, just a build issue. The steering angle sensor can be reset via the ecu. The steering angle sensor is telling the car where forward is. Thank you, yes it still does. I had a computer connected but no steering angle reset option. Mine is mk3 Quote Link to comment Share on other sites More sharing options...
Tony Posted September 8, 2021 Report Share Posted September 8, 2021 Have the tyres been moved side-to--side yet Quote Link to comment Share on other sites More sharing options...
Zeemo Posted October 13, 2021 Report Share Posted October 13, 2021 the tyres moved, I suspect bend frame or something or basically car is so old its out of shape. I have sold it now Thank you for the advice and effort in helping me trying to figure this out. Quote Link to comment Share on other sites More sharing options...
Tony Posted October 13, 2021 Report Share Posted October 13, 2021 Your welcome Quote Link to comment Share on other sites More sharing options...
