3 plugs, and 20 wires tonight..(1.5 hours).
its taking its time...fo sure
but that is now, everything on the steering column re wired less the nice little illuminating ring, around the key
ive still goto rewire the plugs from the drivers side that went into the fusebox, to the fusebox now behind the passenger seat, and then make the wires for the plugs for the passenger side fusebox around 4" longer
then......im at the point i was hoping to be at , last week before i got the car back with the cage in
once im happy everything works again....it will all come out again, the insides will be painted, then
re-install all the loom
put the dash back in
move and tidy up the wires for the F Con V pro
seats in
wire in the new instrument cluster
plumb in the remainder of the fuel system
plumb in the fire extinguisher
blah
blah
blah
