Full Version: Vauxhall Omega Geometry
Wheels-InMotion > Chassis Dynamics Forums > Geometry
Dave Elite
Hello I'm new to this forum so hello to all. I recently had a full geometry done a buckley tyres. I'm still not happy with how the car drives so I have booked in at WIM to have it done properly. Anyway here is the printout. You're thoughts?
Hello
The workmanship is typical..... Poor...... It looks like the car is pulling left with a lazy steering return, the OSF has nearly twice the camber it should have and the sub-frame needs repositioning to correct the castor disparity. Other than that it's fine biggrin.gif
Dave Elite
QUOTE (Tony @ Apr 16 2010, 01:22 PM) *
Hello
Thanks Tony. I'm looking farward to coming to WIM soon. You're correct, the steering is slow and lazy to return, and it does pull left.
In you're oppinion Tony, is it better or worse then before? And why? Also do you reccomend poly bushes for the wishbones on an Omega?
It's better but the stock positions of -1 degree 40' won't work on the car hence the historic problems with inside tyre wear, plus most would say the castor cannot be adjusted........... but we can wink.gif
Dave Elite
QUOTE (Tony @ Apr 16 2010, 02:02 PM) *
He was aiming for -1 deg 10' but said thats as close as he could get it. He loosened both strutt bolts, and one guy pulled the wheel and held it and the other guy quickly did the bolts up with a windy gun, and then he said that will do.
Do you reccomend poly bushes for the wishbones on the Omega?
For the wishbones yes, problem we found was the job was labour intensive meaning it would be cheaper to buy good quality wishbones than poly.
Dave Elite
QUOTE (Tony @ Apr 16 2010, 02:21 PM) *
Thanks Tony, would you reccomend Powerflex?
QUOTE (Dave Elite @ Apr 16 2010, 02:46 PM) *
The members in the owners forum use a generic bushing that i think comes from a BMW, it was really hard.
