These angles are set sequentially in order of how much influence each correction has on other angles, reads complicated but it not.... Basically when the camber is corrected it dramatically changes the toe, so it's wise to move the camber before toe. Anyhoo on this car the final toe positions where very displaced, i corrected the position and then bounced the suspension up/down to relax everything, but then the camber positions changed and where now wrong
Turns out the anti-roll bar is so seized it's holding the suspension position up/down....... Never seen this condition before but hay this is wim.
