I don't know if its very clear in the pictures, but there is a lot of asymmetric wear, with the inside shoulders of both fronts worn down to the limit, with virtually full depth of tread on the outside edge.
Until quite recently, the suspension has had a dash of negative camber, which might explain the wear, but I was also wondering if this exaggerated wear condition might be caused by poor scrub geometry (which I know I have - tread centreline 92mm outside steering axis at last count), or toe-out on braking caused by my recently discovered bump-steer geometry.
Is it possible to differentiate the causal mechanisms based on the appearance of the wear? There is no evidence of any shearing/scrubbing on the surface, just smooth wear. There is virtually no "feathering", and no particular "snagging" feeling if I run the palm of my hand over the tyre in one direction or the other.
My guess is that its camber, but I know nothing about tyres (you probably know this because I have bought a set of cheap Marigolds
Thanks in advance,
Lauren
PS - I should add this tyre is 3 years old and has done around 5,000 miles.
