This is where I want to track the changes to the setup of the car, and more important, why the changes are made and what effect they had!
I think it's important to say that this car is a regular track and drift car - normally these set-ups are quite contradictory.. so this could be a bit of a challenge!
But first an introduction to the car...
This is the roadster in question, a 1992 Mk1 1.6
As you can see its not quite standard, so here are the important mods (trust me, there are many more!)
Aragosta coilovers - 10kg/mm FR, 8kg/mm RR
extended strut towers
Racing Beat antiroll bars
16x6j wheels, equiped with 205/45 Falken FK451s
Suspected Cusco 1.5way diff
Full Roll Cage
And Supercharged...
other things of note - no power steering, and extended final drive
The set-up I started with was as follows (nothing too extreme here)
LEFT / RIGHT / Average
FR Toe :2.1mm / -1.8mm / 0.15mm
FR Camber :-1.85deg / -1.6deg / -1.77deg
Castor :3.56deg / 3.72deg / 3.64deg
RR Toe :1.2mm / 4.1mm / 2.65mm
RR Camber :-2deg / -1.5 / -1.75deg
Comments...
So virtually parallel toe at the front, a healthy amount of toe in at the rear for stability.
Camber was surprisingly even (on average).
and Castor is pretty average.
One thing I wish I had measured was ride hieght... Looking at these numbers the odd thing that stands out is the LH/RH offset. It makes me think that with a driver in the car the numbers would be almost equal! (I might start a separate post about this one - it could be a whole can of worms
This setup had mild amount of understeer, and handling was fairly predictable.
However when drifting I found myself without enough lock! so this was something I wanted to change.
After chatting with Tony, this is what we opted for as a baseline set-up for future development.
FR Toe: 0mm / 0mm / 0mm
FR Camber: -2.3deg / -2.3deg / -2.3deg
Castor: 3.0deg / 3.0deg / 3.0
RR Toe: 1.0mm / 1.0mm / 1.0mm
RR Camber: -1.0deg / -1.0deg / -1.0deg
Comments...
Toe & Camber set up to make the car more neutral and balanced
Castor was taken out to increase Toe-out on turn, to give me that little bit extra lock. Also had the bonus effect of making the steering lighter.
So how did it go?
On track - The car handled beautifully through medium/high speed corners, going from neutral in medium speed corners to gentle O/S through high speed corners (maybe not ideal for everyone, but great for me
On Drift - Once I'd sussed out some reasonable tyre pressures, the car was very well balanced, and easy to both initiate and hold a drift... However in transitions, it wouldn't wind itself from lock to lock quick enough - leading to some pretty embarassing spins. Also any extra lock from the TOOT effect had little noticable effect.
So what next?
Well, firstly I need to out some castor back in, and find another way of adding extra lock. Captain Sideways - who used to run a Drifty MX5 has given me some cunning rack mods to try out, so I'll get them done and then go for maximum castor for know - I subscribe to the motorsport theory of only changing one thing at a time to appreciate the effect it has!
Tony, I'll be back in to see you soon, and then I'll be back here to let you know how it goes.
If any one has any comments, then please throw them in for consideration!
