As you can see it's a trailing arm with a combined spring/shock and lateral link. What interests me is the rear link, which projects over the wheel and is articulated to allow for suspension deflection.
I read in my expensive book the upper link is projected to the top so longitudional complaince can be built in without excessive geometric disturbances ie; where the upper and lower balljoints are spaced closely together, large longitudional compliance in the joints would cause large geometry disturbances, so complaince is designed in elsewhere, usually subframes.
That makes sense in front suspension with SAI, Castor etc but why bother on the rear ?
