QUOTE (Tony @ Nov 30 2009, 08:05 PM)
Hello James
The Porsche rear adjusters are camber and toe but like you said one angle influences the other, so basically you have to optimize them both. Historically the camber correction will massively violate the toe so this is the one to adjust first, then incrementally adjust between the two.
Thanks Tony, this is roughly what I thought just wanted to confirm with someone. Thanks again!
