Full Version: Horror of the week 16/10/09
Wheels-InMotion > WIM General/Community Area > Horror Of The Week
Not only are these brake pipes to long they should be behind the heat shield next to the exhaust down pipe. The heat transmitted to the brake fluid here is an absolute invitation to brake fade or even total failure.......
Click to view attachment
E55EX_RACER
Have these replaced corroded pipes then?
QUOTE (E55EX_RACER @ Oct 16 2009, 08:27 PM) *
I should think so but the route is totally wrong.
E55EX_RACER
QUOTE (Tony @ Oct 16 2009, 08:35 PM) *
If they were OEM I would've thought the job would neater! Did you say anything to the owner?
No...... the owner did the install and i didn't have the heart to belittle his work, what i did do was to tuck the pipes under the shield.
E55EX_RACER
QUOTE (Tony @ Oct 16 2009, 08:55 PM) *
You don't have to belittle someone, just point out it would be a good idea to keep them away from the exhaust for safety reasons. Up to them if they want to sort it out smile.gif
QUOTE (E55EX_RACER @ Oct 16 2009, 09:01 PM) *
E55EX_RACER
QUOTE (Tony @ Oct 16 2009, 09:17 PM) *
Should've left it to the pro's then!
Indeed...... I have the distinct impression the owner was told "whatever you do don't cut them to short"...... The back end looked like a distillery ohmy.gif
E55EX_RACER
QUOTE (Tony @ Oct 16 2009, 09:34 PM) *
If the pipes are longer will they work as effectively or just require more fluid?
QUOTE (E55EX_RACER @ Oct 16 2009, 09:37 PM) *
They would need more fluid.... I believe there's a deterioration in braking performance if the pipes are wound so it's an MOT fail.
hms
Isn't that a fail anyway as the pipework is not secured?
h
QUOTE (hms @ Oct 16 2009, 09:42 PM) *
h
Yes i think it is.
dazz33
ohmy.gif thats a shocking bit of work....was his other car a "Horse"... laugh.gif
In truth i think this is armature work done with the best intentions...... No one in the know would do this intentionally.
E55EX_RACER
QUOTE (Tony @ Oct 17 2009, 07:28 PM) *
I have to agree but why wouldn't you follow the path of the pipes you've replaced, surely the owner must realise they take that route for a reason.
QUOTE (E55EX_RACER @ Oct 17 2009, 07:48 PM) *
Re-word that please... "we" didn't replace anything!.... Agreed he should have followed the original path smile_anim.gif
E55EX_RACER
QUOTE (Tony @ Oct 17 2009, 07:51 PM) *
You know I was referring to the owner not you! As if WIM would do shoddy work like that wink.gif
hms
Had a quick scout around, it also has to be secured every 30cm (max)
Copper when bent work hardens and becomes brittle, so he's at more danger than just boiling his fluid off!
h
E55EX_RACER
QUOTE (hms @ Oct 17 2009, 09:52 PM) *
h
Doesn't look like any of it is secured! He will have a shock MOT time closedeyes.gif
