Full Version: Powerflex Bushes MX-5
Wheels-InMotion > Chassis Dynamics Forums > Shock Absorbers / Springs / Suspension
TarkMalbot
I ave come accros these:
http://www.powerflex.co.uk/products/MX5+MK...+on-2621/1.html
Are they worth the money? Do they make much of a difference? Are they difficult to fit? Will the cars geometry need setting up again?
Janey
They are worth it & they do make a noticeable difference. They can be tricky to fit (main problem is getting the old ones off) and yes I'm guessing the car would need setting up again as you are more than likely removing/undoing things like wishbones & track control arms to fit them. Tony would probably be better clarifying this as he knows the underneath of a 5 better than most biggrin.gif
CIH
I wouldn't expect an NC to be old enough to warrant a bush replacement/upgrade ?
Yep, yep and yep...... Their a bugger to fit, high maintenance and make the car real crashy so think hard before fitting them.
TarkMalbot
Make the car feel Crashy? And High maintenance? Don't think I will bother! lol
E55EX_RACER
I thought poly bushes help firm the car up so why do they make it crashy? Does this only apply to the MX5?
Bazza
i believe Tony means hard and uncompromising when he says "crashy"
the original bushes are rubber, and quite soft so allow absorbtion of vibrations and flex
where as poly bushes are quite rigid and tend to transfer all vibrations directly to what they are joining together
it is a hard choice, the fitting of them will greatly improve the cars handling but they also compromise the cars comfort level
E55EX_RACER
QUOTE (Bazza @ Apr 11 2009, 08:59 AM) *
When you say high maintenance Tony do you mean they just need greasing often? I've a feeling the squeak on mine in coming from the anti roll bar poly bush unsure.gif
The MX5 is no family car though so if it was me I'd be tempted to fit them. Especially with all the other mods fitted to it.
Cheers bazza, you said exactly what my brain thought but my fingers denied.
@ER.... within no time they squeak and moan.... A bit like the wife when she wants you to visit the mother-in-law wink.gif
E55EX_RACER
QUOTE (Tony @ Apr 11 2009, 06:05 PM) *
So what grease would you suggest to stop them squeaking? I sprayed them with WD40 quickly but it didn't work. I suppose I need to undo the clamp to get the grease in properly.
Yep, there's a special grease you need to use.... WD40 just drys out.
E55EX_RACER
QUOTE (Tony @ Apr 11 2009, 08:26 PM) *
Where can I get the grease from and would I have to undo the bracket? I suppose it's the same grease that would be used on the rear arm poly bushes?
rooflessdriver
QUOTE (E55EX_RACER @ Apr 12 2009, 11:32 AM) *
I'd be interested to know which grease it is too.
I had an annoying squeak which Tony pinpointed as the bushes for my rear FM ARB.
He undid the brackets, greased them up and it disappeared.
Just starting to come back again, but only occasionally over sleeping policemen.
Would save me the 130mile roundtrip if I can do it myself!
I've spent some hours online researching this today and found it to be a repetitive question in many clubs.... I'll have to do some more research for a definitive answer.
hms
The answers I found were:
1. White lithium grease.
2. Silicon grease. (Transparent stuff with no additives.) This stuff is available from Maplins and is branded Servisol.)
What you don't want is something that affects rubber so WD40 is out, I'd also be concerned about spray greases due to the solvents used to make the grease sprayable. (Don't know if that is a valid concern!)
h
QUOTE (hms @ Apr 26 2009, 06:45 PM) *
h
That's pretty much the same that i found..... What i couldn't find was a UK supplier of the grease?
hms
QUOTE (Tony @ Apr 27 2009, 11:09 AM) *
h
As I said, Maplins. You should also be able to get it from a Dive shop. It's used for lubricating 'O' rings in the regulator.
h
QUOTE (hms @ Apr 27 2009, 09:40 PM) *
h
h
It's a poor show you have to go to an electrical store to buy grease for your car huh.gif
E55EX_RACER
What about on ebay any on there?
