Eibach appear to have camber adjusters of the ES 250/300, so have asked them if they could be suitable for the IS250 or if not, did they have any plans to design a set.
Here's the ones for the ES. They're available in pairs, either 15mm and 17mm:Car fitment
Lexus: ES250, ES300,
The new EZ Cam XR is designed for non-slotted struts. It allows both positive and negative camber changes up to approximately 1.75 degree (depending on vehicle) by replacing the upper O.E. strut/spindle bolt. This easy to use adjuster provides built-in adjustment over the life of a vehicle just by rotating the head of the bolt. Each kit contains two cam bolt assemblies, enough for both sides of the vehicle. MasterPaks of 10 are available. Use wrench #85825 to adjust.
NO Special Tools
NO Grinding Necessary
Click to view attachmentClick to view attachment
