QUOTE (Mat @ Jan 4 2008, 11:38 AM)
suck.
in blow configuration the fan could act as resistance to air flowing through the matrix, in suck, the air has already done its job.
But you have to look at radiator and fan as a complete system. The cooling capacity is a function of the rate of flow through the system, which is in turn a function of the pressure drop through the whole system. Whether you put the fan on the front or the back of the radiator it still contributes to the total pressure drop when the system is moving through the surrounding air. The shape of the fan and its containing structure may make it more efficient when air is passing through it in one direction as opposed to the other, but that apart, it really ought not to make much difference whether it is on the front or the back of the radiator.
The efficiency of a fan is affected by the inlet and outlet pressures and it may be possible to design fan profiles optimised to reduce sensitivity to either changes in input pressure or output pressure, but not both. So you can produce a fan that works better sucking than blowing, or vice versa. None of the car fans that I have seen appear to have this degree of sophistication, but I am ignorant of any work that may have been done in respect of high performance vehicles. You have only to look at the very complex shapes of aircraft propellors (and take account of their variable pitch arrangements) to know what a complex area of technology this is.
There are so many imponderables, that I would hesitate to generalise. Even if we were to measure the pressure drop through the system with the fan mounted first in front and then in the rear, the measured difference would not necessarily hold good over the whole vehicle velocity envelope from stationary to top speed.
