Full Version: Dampening Question
Wheels-InMotion > Chassis Dynamics Forums > Modifications
TDIPLC
This one is for Tony and any other suspension Genii.
We are developing a new road orientated suspension kit for a car (secret squirrel at the moment) using 3 way adjustable dampers.
We have seen truly amazing results on the track using this system (2 seconds per lap), and was wondering if anyone has any thoughts on this concept or has tried it?
Bazza
QUOTE (TDIPLC @ May 17 2006, 12:42 PM) *
when you say three way adjustable dampers, do you mean height and damping adjustable,
i am using the D2`s on the starlet, and they have an infinate amount of different adjustments, but are track orientated, which means although the can be adjusted for road use they are allways a bit stiff and therefore a bit uncomfortable for everyday road use
presuming road orientated would have a more comfortable ride, but be less suitable for track use
is it possible to have the best of both worlds !!
TDIPLC
QUOTE (Bazza @ May 17 2006, 01:41 PM) *
Three way (or even better four way) adjustable damping is perfect for us mere mortals smile.gif
Let me explain (tapping chalk on blackboard) if I may?
A two way adjustable damper allows you to adjust both bump (compression) and rebound (extension) rates to optimise handling to suit the application in normal use. That's fine, but what happens when the wheel hits a bump or pot hole? The car is sent completely off line because it's applying the same bump/rebound setting to a very fast change in cirumstances as is to it's normal operating conditions.
What 3 and 4 way adjustable dampers allow you to do is to also set the bump and rebound for rapid reactions as well as for the normal slow reacting conditions.
Clearly, there is a layer of cost attached to this so it's not cheap, but anyone that has driven a car with good and bad suspension will know that it's money well spent.
Is this a coil over oil application or just a damper only configuration.
TDIPLC
QUOTE (Tony @ May 17 2006, 03:25 PM) *
It can be either. It can also be gas or oil.
The application we are working on at the moment is a coil over system. Exciting times smile.gif
Bazza
QUOTE (TDIPLC @ May 17 2006, 02:14 PM) *
tsk tsk mark, its whiteboards now !, how long is it since you were at school laugh.gif
if i am understanding this right
normally when three way adjustment is mentioned it is concerning for example a "coilover"
what you are saying is that your three way adjustment is solely concerning the damper
sounds very complex
but also sounds like you can have the best of both worlds
TDIPLC
QUOTE (Bazza @ May 17 2006, 04:56 PM) *
sounds very complex
Blimey I thought blackboards were modern compared to the parchment and quill that I had when I was at school blink.gif
Three and four way adjustable shocks just refers the damping, and is considerably better that 1 or 2 way smile.gif
QUOTE (TDIPLC @ May 17 2006, 02:41 PM) *
Exciting times indeed.... were is your intended market. Road/Track/Race?..... Is the evolution marque specific or global in fitment?.... Also are there additional compliments required to assist or evolve the new damper system.
scorps
What is the weight of these,are they lighter than stock?
Will they have a cooling reservoir?
Can they be reshimed by the owner or will they have to go back to you?
Your 2 seconds a lap quicker?.............wet/dry same curcuit or different?
jon
I've had a fair bit of fun playing with 2 way damping though currently run 1 for track use.
I can see the benefit of 3 way on bad surface but a smooth track? I guess she'll ride the curbs a lot better...
I'm certianly going to follow this with interest (not least because my HAs are getting past their best)
TDIPLC
QUOTE (scorps @ May 17 2006, 10:27 PM) *
There's not generally a significant weight difference between 2 and 3 way adjustables. Where weight is an issue, they can be made in aluminium but that is more expensive.
The project we are working on at he moment is not Japanese related - it's a high value British car whose owners are generally more quality than cost conscious.
The shocks will have to be returned to the manufacturer for revalving.
The issue regarding the reservoir will probably vary according to the application, but a separate reservoir is preferable.
Regarding the 2 secs per lap, it's exacty the same conditions except for changing the shocks.
QUOTE (jon @ May 17 2006, 11:19 PM) *
When a car is set up using one or two way damping (or no adjustment at all), there is a big compromise as it must be set for adequate performance beween slow and fast reacting damping. If it was optimised for slow reacting damping (which most set ups are) the car is unbalanced when a bump or dip is encountered. Conversely, if it is optimised for fast reacting damping, the car will be unstable under smooth conditions.
Imagine a scenario where both conditions can be optimised - thats 3 and 4 way adjustable biggrin.gif
jon
QUOTE (TDIPLC @ May 18 2006, 09:24 AM) *
Now you're just talking dirty...
TDIPLC
QUOTE (jon @ May 18 2006, 09:41 AM) *
QUOTE (TDIPLC @ May 18 2006, 08:24 AM) *
I like this scenario... Weigh plates and 'pull downs' would add an interesting evolution i feel... Has this been explored.. If not can wim assist if only in data analysis furthering development.
TDIPLC
QUOTE (Tony @ May 29 2006, 06:49 PM) *
Quote:TDIPLC
Not at STS unfortunately.... All my math is either in my head or if complicated a few hours with the old pen and paper... Geometry in truth should be as visible as a dyno.. Add every modification to the equation including Dampening/Coil Reaction then an image should be visible though the fog.... But new evolution like this dampening set-up invites constructive/destructive argument.. For Development between fields..... That's a good thing biggrin.gif
TDIPLC
QUOTE (Tony @ May 29 2006, 07:43 PM) *
No doubt loosening the restrictions of your current incarceration will liberate a freedom of thought and actions, therefore your wisdom and knowledge in the field of geometry will be essential to us.
QUOTE (TDIPLC @ May 29 2006, 07:56 PM) *
Excellent opportunity for evolution.... Proof is a foundation....Any takers in wim or TDIPLC Please keep us apprised
jon
My patience, opportunity is waning fast....My release may be premature...... Although my final destination still is not final?
QUOTE (jon @ May 29 2006, 08:23 PM) *
I recall a certain prominent company inviting a target car to 'evolve' for commercial reasons. And a 'ME, ME, 'ME' plea from a wanting recipient.... This marriage has become very visible...... unsure.gif
I would love to expand and assist your final stages mechanically for the race events, i assume you intend to advertise any 'sponsors' on the cars body, but unfortunately I lack the skill.... Maybe your near complete/ race ready example could fall under a similar wing..... who knows smile.gif
QUOTE (TDIPLC @ May 17 2006, 01:14 PM) *
How's the testing going?.....The Monroe Sensatrac tried a similar concept some years ago and failed, i believe because the 'passive' damper was sealed (no adjustment) as a result '3 and 4' was denied compromising the handling during the rapid requirements... Adjustable at the '3 & 4' stage reads very interesting.
