Where You Are!
Where You Are!
Sprung and unsprung weight, A coil explanation...... |
Jun 28 2007, 05:36 PM
Post
#1
Founder of WIM! Group: Founder Posts: 20,289 Joined: 26-March 06 From: Hemel Hempsted Herts Member No.: 2 Vehicle: Honda Gender: Male Country :
Unstrung weight includes the mass of the tyres, brakes, suspension linkages and other components that move in unison with the wheels. These components are on the roadway side of the springs and therefore react to roadway irregularities with no damping, other than the pneumatic resilience of the tyres. The rest of the mass is on the vehicle side of the springs and therefore comprises the sprung weight. Disturbances from the road are filtered by the suspension system and as a result are not fully experienced by the sprung weight. The ratio between sprung and unsprung weight is one of the most important components of vehicle ride and handling characteristics.
![]() Unsprung weight represents a significant portion of the total weight of the vehicle. In today's standard-size car, the weight of unsprung components is normally in the range of 13 to 15 percent of the vehicle curb weight. In the case of a 3,500 pound vehicle, unsprung weight may be as high as 500 pounds. A 500 pound mass reacting directly to roadway irregularities at motorway speeds can generate significant vertical acceleration forces. These forces degrade the ride, and they also have a detrimental effect on handling. Early pioneers believed that the primary job of the suspension system was to absorb bumps and smooth out the ride. Today we understand that an equally important function of the suspension is to keep the tyres in contact with the road. This is not as easy as it might appear to be. When a tyre encounters an irregularity the resulting forces tend to reduce contact pressure and therefore degrade adhesion. Obstacles impart a vertical acceleration to tyres that increases in proportion to the forward speed of the vehicle and the size of the obstacle. The greater the accelerated mass (unsprung weight) the greater the kinetic energy. In a sense, a raised obstacle throws tyres away from the roadway. A depression causes the surface to rapidly drop away leaving the tyre to follow along when inertia can be overcome by the downward pressure of the springs. Both occurrences reduce the tyres contact-pressure and tyres can actually become airborne if the forces are great enough. The forces generated by roadway irregularities (bumps) must be overcome by the springs in order to keep tyres in contact with the road. The force of the springs comes from the compressive load imposed by the weight of the vehicle. The lighter the vehicle, the less compressive force is available, and the easier it is for the vertical motion of the wheels to overcome the inertia of the sprung mass and transfer motion to it as well. The ideal combination occurs when the ground pressure is maximized and inertial forces are minimized by a high sprung-to-unsprung weight ratio. A high ratio keeps the tyres more firmly in contact with the road, and it also produces the best ride. The sprung-to-unsprung weight ratio is particularly important to the design of extremely low mass vehicles. The necessarily higher suspension frequency produces a rougher ride, which can be accentuated by smaller tyres typical of smaller cars. Smaller diameter tyres react more violently to bumps and potholes. Their reduced radius causes them to move deeper into depressions and climb more quickly over obstacles. The higher acceleration rates are offset to a large degree by the reduced mass of the smaller tyres. Tests have shown, however, that smaller tyres do in fact produce a rougher ride, even though they are lighter. With smaller, lighter vehicles, it is even more important to keep the ratio of sprung to unsprung weight as high as possible in order to reduce the undesirable effects of smaller tyres. When the ratio of payload to vehicle weight is exceptionally high, the fully laden weight provides the most valid basis for comparison. For example, the curb weight of town car was only 650 pounds, which at the typical large-car ratio would have provided for a total unsprung mass of less than 100 pounds. At 23 pounds each just for the tyre/wheel assemblies (exclusive of brakes, axles and suspension linkages), it is easy to see that town car was far off the mark. However, the two-up weight of town car was approximately 1,000 pounds. Using the two-up weight of both vehicles, the 500 pound unsprung mass of the 3,500 pound car (3,850 lb with two occupants) equates to a 130 pound unsprung mass for town car, which is more in line with the actual weight of the components. ![]() Regardless of the perspective, every component of the unsprung mass must be more closely scrutinized in low mass vehicles in order to keep unsprung weight to an absolute minimum. The advantages for the designer in this regard are that a low mass vehicle will impose significantly lower structural demands on components, and the lower operating speeds result in greatly reduced unsprung acceleration forces. |
Lo-Fi Version | Time is now: 1st August 2010 - 07:04 AM |
