BillNick Posted November 26, 2015 Report Share Posted November 26, 2015 Hi all, I bought a 2008 IS250 back in July. The previous owner was an honest gentlemen and after looking at the condition of the nsf alloy wheel he admitted to hitting he kerb. The last service bill had tracking and a tyre included. Then he got it MOT'd for me as part of the deal, and there was an advisory "Inner Steering Arm Joint showing signs of play but not excessive". I called the MOT tester who explained it was very very slight and most MOT testers would not have even advised. Bought the car and noticed a pull to the left. Check tyre inflations all ok so took it for a front wheel alignment locally that weekend. The guy that owned the tyre shop explained his alignment was perfect, so if it still pulls something is bent. It still pulls......I can take my hands off the wheel on a slight left hand bend on the motorway and it follows the lines. Having been very pleased with the WIM settings on my old 200, I plan a trip to WIM for a geometry and hopefully a diagnosis of the pull to the left. I want to get this done in December but in the new year I plan to change the factory 17" alloys to OEM 18" alloys. Should I wait until the 18"s are fitted or will it not make a difference on the geometry? Any advice offered for simple DIY checks also welcomed. ThanksBill Quote Link to comment Share on other sites More sharing options...
Tony Posted November 27, 2015 Report Share Posted November 27, 2015 I reads like it needs the full geometry measured rather than just the tracking.... Wheel diameter change isn't a problem unless the toe angles are measured in mm which we don't so we're fine there. Quote Link to comment Share on other sites More sharing options...
BillNick Posted November 28, 2015 Author Report Share Posted November 28, 2015 Cheers Tony, I'll be up to see you soon Quote Link to comment Share on other sites More sharing options...
