parthiban Posted January 15, 2013 Report Share Posted January 15, 2013 This is a little embarrassing but a good reminder of how a little neglect can go very wrong very quick! The geo on the Merc has felt a bit off for a few months (slight pull to the left) but car felt ok so didn't do anything about it assuming there was time. Got the tyre pressure warning indicator pop up last weekend, checked the tyres and the front left looked low - tried to pump it up and it wouldn't go above 26psi so took the wheel off and discovered this This was obviously a lucky escape and a stark reminder to check my tyres on a regular basis and to maintain regular geos! See you on Saturday Tony Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2013 Report Share Posted January 15, 2013 I admit I don't check my tyres as often as I should but our cars aren't known for any wear issues like that. I always run my hand across the whole tread to check they are even though. Are they runflats or normal tyres? Quote Link to comment Share on other sites More sharing options...
parthiban Posted January 15, 2013 Author Report Share Posted January 15, 2013 While inner wear issues were common on the Lexus I don't think it's a problem on the Merc (unless Tony knows otherwise). Give the tyres a quick glance visually every now and then but will start feeling through regularly (as in the pic the rest of the tyre looks spot on, it was only the very inside edge. These are normal tyres, not runflats, surprised it held together so well - was quite shocked when I saw the state of it. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2013 Report Share Posted January 15, 2013 You were lucky it didn't blowout when driving but like you say when the rest of the tyre looks fine it can be easy to miss. Does the merc have adjustable camber? Quote Link to comment Share on other sites More sharing options...
parthiban Posted January 15, 2013 Author Report Share Posted January 15, 2013 You were lucky it didn't blowout when driving but like you say when the rest of the tyre looks fine it can be easy to miss. Does the merc have adjustable camber? Absolutely, it really was a lucky escape. Will be paying a lot more attention going forward. I think it doesn't as standard, but there are some adjusting bolts that Tony got for us last time it was geo'd that allow camber/castor adjustment. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 15, 2013 Report Share Posted January 15, 2013 Historically the Merc's only suffer with pulling issues, that wear looks camber related. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2013 Report Share Posted January 15, 2013 Maybe the camber bolts need re-adjusting? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 15, 2013 Report Share Posted January 15, 2013 The bolts give a fixed range, so you could fit one and still not get the camber right. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2013 Report Share Posted January 15, 2013 But wouldn't that of shown up on the geo when it was done after fitting? Quote Link to comment Share on other sites More sharing options...
parthiban Posted January 15, 2013 Author Report Share Posted January 15, 2013 The geo hasn't been done for a while, so it's most likely with all the potholes around it's been knocked out. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 15, 2013 Report Share Posted January 15, 2013 I agree otherwise we would have fitted camber adjusters. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2013 Report Share Posted January 15, 2013 That's what I meant when I said they need re-adjusting, i.e. the geo has been knocked out cos of the roads. Quote Link to comment Share on other sites More sharing options...
parthiban Posted January 15, 2013 Author Report Share Posted January 15, 2013 I agree otherwise we would have fitted camber adjusters. Were the bolts fitted last time for caster then? I know you fitted some bolts from MB but can't remember what they were. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 15, 2013 Report Share Posted January 15, 2013 Was the car pulling left last time you came in. Quote Link to comment Share on other sites More sharing options...
parthiban Posted January 15, 2013 Author Report Share Posted January 15, 2013 Was the car pulling left last time you came in. Can't remember for sure but off the top of my head I don't think it was. Are the bolts something you keep in stock in case I do need them on Saturday? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 15, 2013 Report Share Posted January 15, 2013 I have them in stock. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2013 Report Share Posted January 15, 2013 Was the car pulling left last time you came in. Can't remember for sure but off the top of my head I don't think it was. Are the bolts something you keep in stock in case I do need them on Saturday? I thought you said earlier the car already had them fitted? Quote Link to comment Share on other sites More sharing options...
parthiban Posted January 15, 2013 Author Report Share Posted January 15, 2013 I have them in stock. Cool thanks. I thought you said earlier the car already had them fitted? There were some MB bolts fitted last time but I have no idea what they were for - if there is only one then I think I have them, if there are more than one then I might not!? Tony asked above whether the car was pulling last time which I don't think it was, so maybe I don't have these ones fitted. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 15, 2013 Report Share Posted January 15, 2013 Lets hope it was castor bolts/s that were fitted because that means i can fit camber bolts if needed. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2013 Report Share Posted January 15, 2013 Do you have the last geo printout from when the bolts were fitted and see what was adjusted against the before readings, camber or castor? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 15, 2013 Report Share Posted January 15, 2013 I will be able to tell by looking at the bolts. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2013 Report Share Posted January 15, 2013 I will be able to tell by looking at the bolts. Yeah that's not until Saturday, if he wants to know now then the geo report should be able to show what bolts were fitted. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 15, 2013 Report Share Posted January 15, 2013 The i need the registration number to pull the report. Quote Link to comment Share on other sites More sharing options...
parthiban Posted January 15, 2013 Author Report Share Posted January 15, 2013 I'll forget to look for this when I get home, Tony I've PM'd you the reg Quote Link to comment Share on other sites More sharing options...
Tony Posted January 15, 2013 Report Share Posted January 15, 2013 The geo report was one of the one's lost when my hard drive died but the invoice says we fitted on camber bolt. Quote Link to comment Share on other sites More sharing options...
