Mx5 Nc, How low?
MazdaKev
Hi
I'm new to the forum and wondered if I can get some advice.
I have a 2006 mazda mx5 1.8.
I have purchased a set of Eibach 45mm lowering springs, my question is......is this too low?
I have the standard 16" alloys, will they rub anywhere?
Also I intend to have the wheel alignment done but if I I  then fit 17" wheels would this affect the wheel alignment again?
I would very much like to keep the 45mm lowering springs but if it turns out it's inadvisable to fit them I am able to change them.
Lastly, what sort of cost should I expect to pay for wheel alignment designed for road use.
Many thanks.
Hello Kevin
As said on the phone -30mm is best for the handling and looks. Good question about the wheel size though. 16" or 17" makes no difference unless their very heavy or have a non OEM off-set. Our issue would be the width. The wider tyre needs more static toe because there's more rolling resistance but the actual change would very small.
