Tony's Ferrari F360 blog....
As suggested i have one of these from Amazon on the way
And I've found the port for it to go in the cabin.
Also today I've fitted the nav-pod and the new radio which is working fine although i have to re-fit all the dash yet.
This is somewhat worrying re the bluetooth> https://www.youtube.com/watch?v=Bb3crGQ9FA0
The eml327 is fine for reading fault codes but for live data its a bit slow , also it stays powered up so leaving it connected will drain your battery but it will be sufficient for testing so try it and then I will recommend a better one
I'll go by what you suggest?.... Is there a better one, i would rather get it right from the get go.
Loads more bits ready to go....
Item specifics Condition:
New: A brand-new, unused, unopened and undamaged item in original retail packaging (where packaging is ... Read moreabout the condition
Type: Tablet Resolution: 1024 x 600 Brand: Lenovo Processor: Quad Core MPN: Does Not Apply Processor Speed: 1.30GHz Storage Capacity: 16GB RAM: 1GB Operating System: Android 7.X Nougat Internet Connectivity: Wi-Fi Screen Size: 7in. Hardware Connectivity: Bluetooth, USB, Wi-Fi Contract: Not Applicable Features: Bluetooth, Built-in Front Camera, Colour Screen, Email, Expandable Memory, Integrated Dictionary, Integrated Speakers, MP3 Player, Touch Screen, Web Browser Carrier: Not Applicable Network: Not Applicable Colour: Black EAN: 192076775477
Now the ICE is working it was obvious the speakers needed changing
Some spec's
  • Pair of 6x9" (15x23cm) car speakers with 2 x 500W max. performance / 100W max. overall performance | High SPL capacity: 91dB | 3-way coaxial design
  • Stylish blue light effect - 6 LEDs per cover - reflects on the white injection-cone membrane | Frequency response: 70Hz to 20kHz
  • 1" (2.5cm) ASV voice coil | 0.5" (1.5cm) neodymium tweeter | 20oz (570g) strontium magnet
  • The Auna CS-LED69 car speakers have a 3-way coaxial design and 1000W maximum power to produce an intense bass sound. | The materials used in the Auna speakers are selected for their weight and strength which ensure an excellent mid-range clarity and prevent any distortion. The relatively large ASV voice coils also provide an especially enhanced performance.
  • The neodymium tweeter generates a particularly strong magnetic field, which increases the sensitivity of the voice coil and provides an optimised quality of sound. | For added visuals, the speakers come with LED studded speaker covers, which emit a stylish blue light. Perfect for showing off your system at tuning shows, car fairs or similar events.
To be continued....
Finally have the OEM glass fitted...It really was a labour of love mainly because the OEM glass was slightly wider and curved. As said before i did try to get the glass cut but being toughened any cutting would shatter it, so this meant i had to trim the honeycomb grill on one side but it opened a problem that being cutting it straight, so here it is but a little more work on the grill is needed.
I think you might have problems fitting those. The standard ones seem to be 5.25" but 6" do fit. I think 6 X 9s in the doors will take more than some fettling. Probably more aggro than it's worth :(
