Tony Posted May 30, 2017 Report Share Posted May 30, 2017 Ummm why not turn off the mains?.... Quote Link to comment Share on other sites More sharing options...
P4UL T Posted May 30, 2017 Report Share Posted May 30, 2017 Oh my days, I didn't watch it all but maybe they couldn't, maybe it was the stop c**k he was trying to change? It almost looked like they were expecting it as they had the wet vacs ready Quote Link to comment Share on other sites More sharing options...
Rich Posted May 30, 2017 Report Share Posted May 30, 2017 If it was the stop c**k they were changing can't the water be turned off at the street first? Quote Link to comment Share on other sites More sharing options...
Tony Posted May 30, 2017 Author Report Share Posted May 30, 2017 I thought there would be an in line valve to close and even if there's not he should have turned on every cold tap the relive the pressure. Quote Link to comment Share on other sites More sharing options...
liner33 Posted May 30, 2017 Report Share Posted May 30, 2017 I saw this apparently the stop c**k was elsewhere in the block of flats and he couldnt access it . Landlord wanted it done quickly and cheaply so guess he was disappointed Quote Link to comment Share on other sites More sharing options...
Tony Posted May 30, 2017 Author Report Share Posted May 30, 2017 Blimey only one stop c**k in the entire flats.... Talk about zero redundancy. Quote Link to comment Share on other sites More sharing options...
NickT Posted May 30, 2017 Report Share Posted May 30, 2017 Sad as it sounds, I always wd40 and operate the stop cocks in the house/ garage every year just before winter to make sure they do move and work. In the garage I've put a secondary in-line stop c**k and a drain down valve as a precaution. Quote Link to comment Share on other sites More sharing options...
Tony Posted May 31, 2017 Author Report Share Posted May 31, 2017 I think you are spot on rather than sad..... I did this once a year after i had a flood i couldn't stop Quote Link to comment Share on other sites More sharing options...
