Viking Posted May 20, 2018 Report Share Posted May 20, 2018 Posting this on behalf of someone who can't register. Tony, this is the guy I messaged you about. Got my company 2017 Superb Estate back yesterday from the bodyshop who have spent 3 months repairing a light, offside front smack in the snow. Car slid at about 10mph in 1st gear on a hill into one of those little bridges with concrete bollards supporting a scaffold pole railing. New bumper, bonnet, wing, driving light, headlight, grill and various auxiliary components under the bonnet. The lengthy wait to get it back was caused by the "Bumper Harness" which was on back order with no replenishment date. Anyway, I digress. The week before the bump, I'd had the two front tyres replaced like-for-like for Pirellis as they'd worn the inner edges almost to cords - incidentally, I'd asked our procurement department for Michelin Cross Climates as I live very rurally and start out at 05:40 in the morning, so I get below 8 degree starts for a lot more of the year compared to most, but they wouldn't do it. Two days later we had big snow, I had my bump, and now they've got a £2,500 excess bill and 3 months car rental to pay. All for the sake of an additional £20 per tyre x4 compared to the Summer tyres I now have instead. I'd have never had such an accident with any type of Winter tyre or the Cross Climates, as the car probably would't have slipped away from me at that sort of speed, and I would almost certainly have been able to stop it! The leasing company insist on us using ATS and it turned out that the branch I used in Market Harborough don't have the settings for aligning wheels on the current Superb. Only the old one. I also discovered the lease company won't pay for rear wheel alignment, only the fronts. Seeing an opportunity, I asked the bodyshop to align all 4 wheels as part of the repair process, and attached is the print out they've sent back with the car. It's black and white unfortunately, but laid out next to the accurate colour report I snatched from another post on this forum, mine on the surface at least, looks somewhat outside tolerance. In the "Before" example, mine looks almost right. In the "Current", the left-front is quite vastly different. I'm now concerned that by lining up the geometry, it's exposed that either the suspension hasn't been refitted to the car properly, or that the bump's caused the car's frame to twist somewhere. Obvious solutions would be to either have the car put on a Hunter somewhere else for further alignment, and another would be to chuck the car back at the bodyshop, but that causes all sorts of other issues so I'd rather avoid it if I can. Does anyone have a solid idea if the attached black and white "Current" set up in the lower image is OK? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted May 20, 2018 Report Share Posted May 20, 2018 So was the before done before the accident or before they started the adjustment AFTER the repair? Quote Link to comment Share on other sites More sharing options...
Tony Posted May 20, 2018 Report Share Posted May 20, 2018 Several issues i have there...Both the front cambers are to deep ( negative ) but they are not independently adjustable. In this case the sub-frame needs to be moved to allow the cambers to be optimised. This all good and well assuming one camber is wrong so moving the sub-frame will lessen one side and increase the other. In addition this car has a specific suspension code and i think the datum overlapped is wrong?.. This code will provide the datum for OEM height, rough-road height, lowered height, loaded height and so one. The machine asks for the code which is on an ID paper in the boot or the first page in the service book. Nevertheless the wear problem remains.. One area is option wheels which have a different off-set. It's possible the coils have sagged and in doing so deepening the camber?.. Ultimately independent camber adjusters are the solution but this will be an after market product. For now i would check the suspension code. Currently the report says "standard suspension" and you can just see part of the code on the print starting with a "G". 1 Quote Link to comment Share on other sites More sharing options...
