lowering and alignment
phill_g
HeY,
I'm looking my car with koni str.t shocks and H&R springs. I'm just wondering if i am going to need a camber adjustment kit for my car Before I come to you to get an alignment done? It's a 2010 mazda 3
Cheers
Phill
Ok that's great thanks, do you sell these parts if I was to just bring it Up as I dont have a clue what I'm getting tbh!! I seem to remember it having a very small amount of adjustment. Is it just fronts or rear aswell?
I'm pretty sure it's independent rear suspension.. The koni struts don't come with any top mounts as you are supposed to reuse old ones with them altho I will be fitting new lemforder oem mounts. Here is a link to the kit I'm getting if any use:
http://www.demon-tweeks.co.uk/performance/suspension-kits/car/mazda/3-09-on/koni-str-t-suspension-kit-lowers-front-30mm-and-lowers-rear-30mm-2
Ok if all the struts have two lower pinch bolt holes the all you need to get is some EZ camber adjuster bolts which look like this
You can get them from Demon tweeks, they come two to a box so you need two box's.
