SMARTLY Posted January 20, 2017 Author Report Share Posted January 20, 2017 Well my car has been in for three days this week for diesel filter, new SD card for satnav as online update doesn't work, front parking sensor which was replaced before but error codes had not been cleared, clock losing time and a replacement boot seal whilst it was there as people have reported the boot lid hitting the bumper and damaging the paint. Went out this morning and warning boot not closed on the dash. So tried opening and closing it but error still there. So can't lock car Called out Jaguar Assistance hopefully to resolve. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 20, 2017 Report Share Posted January 20, 2017 Let's hope it's something simple....Bit annoying though. Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 20, 2017 Author Report Share Posted January 20, 2017 It's simple all right, I need to go the gym It just needs a bit more force when shutting. Silly really that it can physically close in two different positions about 2mm apart. I'll have a look at the catch and see if it needs a bit of cleaning or lubrication. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 20, 2017 Report Share Posted January 20, 2017 Sounds like the latch needs moving. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 22, 2017 Report Share Posted January 22, 2017 That's strange, you shouldn't have to shut a boot that hard for it to close properly. On the Accord I don't even have to shut it completely, just put it down and then the motor closes it properly. Quote Link to comment Share on other sites More sharing options...
liner33 Posted January 22, 2017 Report Share Posted January 22, 2017 That's strange, you shouldn't have to shut a boot that hard for it to close properly. On the Accord I don't even have to shut it completely, just put it down and then the motor closes it properly. Same on my XF Quote Link to comment Share on other sites More sharing options...
Tony Posted January 22, 2017 Report Share Posted January 22, 2017 Has it got a boot button "open/ close" Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 22, 2017 Author Report Share Posted January 22, 2017 Mine's only got an open. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 22, 2017 Report Share Posted January 22, 2017 When you press open does it lift or just unlock. Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 22, 2017 Author Report Share Posted January 22, 2017 It opens and partially lifts. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 23, 2017 Report Share Posted January 23, 2017 Right so should it do that for locking? Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 23, 2017 Author Report Share Posted January 23, 2017 No, locking is by manually closing the boot. Quote Link to comment Share on other sites More sharing options...
liner33 Posted January 23, 2017 Report Share Posted January 23, 2017 No, locking is by manually closing the boot. I think Tony means it should soft close , like the Accord and my XF , you simply lower it down and the motor pulls it down the last few mm to shut Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 23, 2017 Author Report Share Posted January 23, 2017 No motor to close it, I think that's available on the XE as an option. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 23, 2017 Report Share Posted January 23, 2017 Bugger..... Back to the latch then, Quote Link to comment Share on other sites More sharing options...
Rich Posted January 23, 2017 Report Share Posted January 23, 2017 All that money on a Jag and they can't even fit a motor as standard to close the boot! Quote Link to comment Share on other sites More sharing options...
Tony Posted January 24, 2017 Report Share Posted January 24, 2017 Have you tried moving the boot catch? Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 24, 2017 Author Report Share Posted January 24, 2017 No. I'm not moving it. But I will try cleaning and lubing it. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 24, 2017 Report Share Posted January 24, 2017 Is it a known issue in the Jag forum? Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 24, 2017 Author Report Share Posted January 24, 2017 No. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 24, 2017 Report Share Posted January 24, 2017 Well it can only be the latch or hasp so time for a fiddle me thinks. Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 24, 2017 Author Report Share Posted January 24, 2017 Been and had a look, cleaned up both sides and put a small amount of lithium grease on. OPened and closed it about 10 times but no difference. Even when it's closed properly you can push down on the lid against the new seal. So can see there is much I can do apart from close it with a little more force than I was before. It's not slamming it so not a big deal I guess. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 24, 2017 Report Share Posted January 24, 2017 Could you raise the latch with maybe a washer? Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 24, 2017 Author Report Share Posted January 24, 2017 Don't think it needs raising as that is likely to put the boot out of line with the wings, if it doesn't settle down I'll drop it back in to a dealer sometime. Quote Link to comment Share on other sites More sharing options...
liner33 Posted January 24, 2017 Report Share Posted January 24, 2017 It could be the seals are cold and less flexible , perhaps some of this stuff may help, I had to buy some with the 370 as the door seals would freeze up in the winter https://www.amazon.co.uk/Gummi-Pflege-Rubber-Stick-100ml/dp/B007TNOQDI/ref=sr_1_1?ie=UTF8&qid=1485284072&sr=8-1&keywords=gummi Quote Link to comment Share on other sites More sharing options...
