thecremeegg Posted October 27, 2014 Report Share Posted October 27, 2014 Right so I have a problem in that as soon as I get to around 45-50mph my wheel starts to shake quite badly. I assumed it was the front wheels being out of balance and so took it to a tyre place and they've "balanced" them but the problem persists. It gets worse the faster I go and doesn't seem to die off after 70mph like wheel balance issues tend to. I know that there seems to be huge variation in wheel balancing machines but does it sound like the wheels or would it be something else like bushes etc? Any ideas welcome! Thanks Quote Link to comment Share on other sites More sharing options...
NickT Posted October 27, 2014 Report Share Posted October 27, 2014 Are they aftermarket alloys? If they are hub centric they might need a spigot ring fitting. .. This is assuming that the tyres aren't cheap nasty dodgy brands ditch finders Quote Link to comment Share on other sites More sharing options...
Tony Posted October 28, 2014 Report Share Posted October 28, 2014 I agree with Nick..... Also does the frequency/ pulse change with speed or is the vibration the same regardless? Quote Link to comment Share on other sites More sharing options...
thecremeegg Posted October 28, 2014 Author Report Share Posted October 28, 2014 Hi guys, They are aftermarket but had the wheels on my old MX5 and this one for a while with no spigots. The tyres are all pretty new Rainsport 3s so they should be ok. It gets more intense in terms of vibration the faster I go yes, 70mph can be really shaky. Quote Link to comment Share on other sites More sharing options...
Tony Posted October 29, 2014 Report Share Posted October 29, 2014 Critical question, what happened to the car between everything being ok and now. Assuming it was ok before? Quote Link to comment Share on other sites More sharing options...
thecremeegg Posted October 29, 2014 Author Report Share Posted October 29, 2014 Nothing noticeable, used to be fine, seems to have just got worse. I've ordered some spigots which arrive today and see if they help but otherwise is it something I can come in for you guys to look at on friday? Quote Link to comment Share on other sites More sharing options...
Tony Posted October 29, 2014 Report Share Posted October 29, 2014 Spigots are essential if required.... 9 times out of 10 you might get away with the wheel being in the centre when re-fitted, more so if air guns are "NOT USED" but that one time it's off then it opens a whole world of hurt. Quote Link to comment Share on other sites More sharing options...
thecremeegg Posted October 29, 2014 Author Report Share Posted October 29, 2014 Ok noted, we'll see how they work. It's weird as I've had the wheels on my previous MX5 and this one without issue until recently, perhaps I've been lucky! Quote Link to comment Share on other sites More sharing options...
Tony Posted October 29, 2014 Report Share Posted October 29, 2014 Have you or anyone checked the wheels fit on the hub? Any up/ down side-to-side movement before the nuts are done up is a bad thing, not only because of the vibration but also because they can come loose. Quote Link to comment Share on other sites More sharing options...
thecremeegg Posted October 29, 2014 Author Report Share Posted October 29, 2014 I haven't actually, thanks for this help, all appreciated. You guys were great at setting up the geo on the car earlier in the year! I'll hopefully fit the spigots tonight and have a check for play etc. Quote Link to comment Share on other sites More sharing options...
Tony Posted October 29, 2014 Report Share Posted October 29, 2014 If it's due to the rings it will be an immediate fix. Quote Link to comment Share on other sites More sharing options...
thecremeegg Posted October 29, 2014 Author Report Share Posted October 29, 2014 That's what I'm hoping for! Quote Link to comment Share on other sites More sharing options...
Tony Posted October 29, 2014 Report Share Posted October 29, 2014 Bet you £20 Internet pounds Quote Link to comment Share on other sites More sharing options...
thecremeegg Posted October 29, 2014 Author Report Share Posted October 29, 2014 Deal! Quote Link to comment Share on other sites More sharing options...
Tony Posted October 29, 2014 Report Share Posted October 29, 2014 Quote Link to comment Share on other sites More sharing options...
thecremeegg Posted October 29, 2014 Author Report Share Posted October 29, 2014 I might owe you 20 of your finest Internet pounds....Fitted the spigots and from my brief drive to 60mph it seemed fine. I will give a proper run tomorrow but fingers crossed it's all good! Quote Link to comment Share on other sites More sharing options...
NickT Posted October 29, 2014 Report Share Posted October 29, 2014 Hey, where's my £20 ???? I'll settle with Kudos from Tony Quote Link to comment Share on other sites More sharing options...
thecremeegg Posted October 30, 2014 Author Report Share Posted October 30, 2014 Now now let's not fight......£10 each? Quote Link to comment Share on other sites More sharing options...
Tony Posted October 30, 2014 Report Share Posted October 30, 2014 Well that is great news and for me comforting knowing the wheel/ s aren't going to fall off now. Quote Link to comment Share on other sites More sharing options...
