Horror of the week 28/ 09/ 11
Peugeot had some impact damage to the NSF "A" company replaced the Track Rod End due to the damage and advised the alignment was corrected, all good advice but what about the......
Bent steering arm
Or maybe the bent Drop-link
I honestly fail to understand a Track Rod end was replaced and these bent components were not spotted?
As you can see it's also had a new ABS ring fitted to the CV joint so one would assume a competent mechanic did the work? In addition after an impact the rule it to look for bent components, some might be hard to see but this is a joke.
